Subaru Tech All We'll Drive
brake fluid?
Old Jul 21, 2003 | 07:46 AM
722ish's Avatar
ASM FTW!
Default brake fluid?
brake fluid, where can i get decent stuff around here anywhere? something that would be relatively compatible with STi 4 piston calipers and porterfield r4s pads.... i just dont want the factory crap to cause problems, and i dont wanna bleed the shit once a week....
95 Supra Turbo 6 speed
11 SWP STI sedan
Old Jul 21, 2003 | 10:38 AM
M249SAW's Avatar
Firemedic / Local 4420
ATE Super Blue. You can find it anywhere on the internet.
Or Motul.
I need to start carrying it.
Old Jul 21, 2003 | 12:31 PM
Dirt Man's Avatar
Sucks to be You!
try Teagues Auto Parts. Dale has Motul RBF600 Brake Fluid for $15.00
www.boxer4racing.com
Old Jul 21, 2003 | 02:05 PM
lstepnio's Avatar
1337 H4x0r
I use the reasonably priced Valvoline synthetic available at just about every local autoparts store and it's a HUGE over the the OE stuff that was in there. The OE stuff bubbled up really quick at a SCCA Solo I Time Trial event, but at the next event the Valvoline didn't even a bleed after a two day event.
I doubt you need anything more hardcore than that Valvoline stuff unless you're running in some type of sanctioned road racing event anyways. I would flush(not just bleed) once a year just to be a good boy to your brakes regardless of what you end up using. Besides, the more hardcore stuff tends to absorb moisture very quickly and requires frequent replacement.
Good luck!
edit:
I also enjoy the incandescence of a CEL in the evening...
You know there's an easy fix for most of the performance related CELs, right? Ask away if you're not aware of these easy solutions.
-luke [www.majjix.com]
Old Jul 21, 2003 | 02:09 PM
722ish's Avatar
ASM FTW!
i dont like waiting for mailorder stuff....
i want it now...
i was just wondering seeing as picking it up would be easier for me!
thanks for the help...
11 SWP STI sedan
Old Jul 21, 2003 | 02:10 PM
722ish's Avatar
ASM FTW!
yeah i know... i just keep getting the EGT light!
dont know why or how, and ive gone 30 odd thousand without a problem, now i havew had it 3 times in a short period of time!
11 SWP STI sedan
Old Jul 21, 2003 | 04:19 PM
TampaWRX's Avatar
danse
I use the Valvoline synthetic as well and though I've not tracked the car, I don't plan on getting the brake fluid above 500degF anytime soon on the street, so no worries. It's cheap, it has a near DOT5 rating and is fully compatible with regular DOT3 and DOT4 fluids, just in case you leave a little in the system after bleeding.
“You will never do anything in this world without courage. It is the greatest quality of the mind next to honor.” - Aristotle (384 BC-322 BC)
Want to know what the war in Iraq is really costing America? Click here
Old Jul 21, 2003 | 11:25 PM
722ish's Avatar
ASM FTW!
hmm, man.. i dunno..i need to stop thinking
11 SWP STI sedan
Old Jul 22, 2003 | 03:26 AM
M249SAW's Avatar
Just stay away from true racing brake fluids. They are very hydroscopic and needs to be bled after every race.
Also stay avay from DOT 5 since it is a silicon based fluid. I will reak havok on your ABS system. DOT 5.1 is ok though.
Kyle
