Marjor garage clean out tons of $5 7M-GE & GTE parts
EMAIL: bulldoglover91109@yahoo.com
PAYMENT PREFERENCE: PayPal
I can be contacted via PM, email, text or phone (813)-five four one-four three seven zero
OK there's a ton of extra parts that I have here there just taking up tons of room. I really need to just get rid of them. Most of these parts are $5 plus shipping. Honestly if you see something you can use please just PM me, and we can work something out. So I guess they are considered O.B.O, but they have posted prices.
Most items will be shipped via USPS flat rate boxes so shipping charges will not be much at all.
IF anyone doesn't see something they need, PM me, I might have it
A1, 2, 3 - Spare head lights $5 + shipping
B. Misc. heat shield for GTE manifold $5 +shipping
C. 3" ct-26 turbo elbow wrapped in titanium head wrap $30 + shipping
D. GTE reservoir power steering mounting bracket $price for shipping
E. GTE power steering reservoir $5 + shipping
F. GTE sending fuel line $5 + shipping
G. 7M alternators both work great. $10 + shipping
H. 7M alternator belt tension bracket $5 + shipping
I. 7M rear timing cover $10 + shipping
J. AC belt tensioner $price of shipping
K. GTE upper dip stick guide $5 + shipping
A. 7MGTE Intake Manifold $20 +shipping
B. 7MGTE Intake Manifold $20 + shipping
(these come with no gaskets, sensors, bolts)
A. 7MGTE 10 blade clutch fan (will fit GE's) $10 + shipping
B. Cross Drilled rotors (not slotted)(will only fit front hubs) $25 +shipping
C. 7MGTE oil pan $10 + shipping
D. Chassis Brace (gets installed directly under front of bell housing w/ bolts) $10 + shipping
E. 7MGTE throttle puller (opens throttle body) $10 + shipping
F. MK3 radiator mounting brackets $5 + shipping
G. 7MGTE 3000 pipe $10 + shipping
H. Coil pack and bracket $15 + shipping
I. 7M~R154 bell housing plate x2 $5 + shipping
J. Working CPS missing plug $5 + shipping (drift-motion sells both the male and female replacement plugs)
K. 7M~R154 bell housing $20 + shipping
A. 550 EV1 Injector clips $5 + shipping (for the set)
B. CT-26 v-band $pay for shipping
C. CT-26 water pipe $5 + shipping
D. 7M-GTE water neck (no sensors) 5 + shipping
E. AC compressor (not sure if it works) $5 +shipping
F. 7M-GE 5 Speed yellow plugged ECU $20 + shipping
G. Fuse block cover $shipping?
H. R154 braided stainless steel clutch line replacement $30 + shipping
I. IACV breather tube $5 + shipping
J. IACV works $10 +shipping
K. 7M-GTE oil pump (works but I would recommend a cleaning and or re-shimming) $20 + shipping
A. 7M-GTE solid sending fuel line $5 + shipping
B. 7M-GTE PCV tube $10 + shipping
C. 7M-GTE power steering reservoir $5 + shipping
D. 7M-GTE throttle body (came off a auto car, there is a difference) $30 + shipping
E. AC compressor fans (work great) $10 + shipping
F. 7M-GTE crank balancer $10 + shipping (no bolt)
G. CT-26 oil feed & return hard-pipe $5 + shipping
H. CT-26 waste-gate $10 + shipping
I. GTE cam gears (will work on GE) $5 + shipping for set
A. 89+ corners $20 + shipping
B. 7M-GE intake Y-pipe & throttle body (includes working TPS) $20 + shipping
C. 89+ side markers $5 + shipping
D. 7M-GTE oil pump drive (and gear not pictured) $25 + shipping
E. 7M-GTE fuel rail (w/ mounting bolts not pictured) $10 + shipping
F. 7M-GTE lower timing cover $10 + shipping
A. Pre 89 corner lights $20 + shipping
B. Radiator over flow $10 + shipping
C. 7M-GE power steering reservoir $25 + shipping
D. 7M-GTE throttle assembly (no rod) $shipping
Misc. sensors, computers, parts... like mentioned above if you need an off item just PM me there's a good chance I may have it.
1986 Toyota Supra Hardtop NA (Maroon)
1989 Toyota Supra Targa CT-26 (White w/ Black accent haha)
chevypower17
For Sale/WTB Honda & Acura
13
Feb 12, 2011 12:06 PM
fdcdude
Jan 27, 2010 09:47 AM
DannyEK4
46
Mar 4, 2009 05:31 AM
Punkinterviews
24
Jan 25, 2006 02:25 PM
