FS r154(MC parts built) and ORC clutches
more class than college
on
FS r154(MC parts built) and ORC clutches 1JZ
well I got a v160 now so this stuff is for sale
R154 with billet shift fork, all new bearings, syncros, seals, MC thrust washers, and Heavy duty bearing retainer. Also has jz bellhousing....950
ORC hyper single for jz comes with push to pull conversion needs new friction disc, can be bought from orc for 250 or get south african clutch guys to make you a disc for about 80, holds 400+ great for getting the weight off the rotating assembly.....600
ORC 709 twin disc for JZ. BRAND NEW friction discs, not even taken out of bags(600 dollars 3 month wait), comes with push to pull conversion and nismo slave(uses a 240sx slave so this is easy to replace if it went out). All bolts and hardware included. holds up to 800hp. Amazing clutch.....1400
both clutchs are the integrated flywheel type so this will replace the flywheel as well.
shared_pm or call
941-306-8270
shared_pm or call
941-306-8270
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
on
cool. thats gonna be awesome. I assume you have seen cowboy bebops supra?
on
on
bump.
on
on
on
