S14 SR Heads, Block, Cranks and other parts.
Have two S14 SR heads, one has 8 bent valves, other one is fine.
Two SR Cranks, the one that came out of the block has stripped threads for flywheel bolts. Replacement crankshaft is used OEM, not re-manufactured. All journals measured in spec.
SR Block w/ pistons and rods still in bore. (Low mile Automatic)
Valve cover
Transmission
Intake
Oil pans
All original bolts, bagged and labeled.
Just needs new rod and crank bearings for new crank.
Complete motor, minus harness, ecu, turbo.
$350 takes everything. 727-278-3904 Nate
I will split stuff up, but you'll get a better deal buying the whole lot.
Valve cover
Transmission
Intake
Oil pans
mr2tin
For Sale/WTB Toyota
12-17-2010 06:06 AM
