2 s13 sr20 part outs, heads, rods, oil pumps, rear mains, oil pans, CAS, much more
Formerly IThaJokaI
on
Well I had another thread, but it started to get long so here it is again.
I have 2 s13 sr20s for parts, 1 rod knocked 1 melted a piston.
here is the parts I have
2 good condition heads w/ cams, caps, shims and guides in place - $100 each
set of rods from a motor with a melted piston - $20 obo
front cover, no leaks good oil pressure when on motor - $40 obo
s13 CAS - $50 obo
2 sets of coils packs with harnesses - 100 obo each
2 sohc mafs w/ 1 pigtail works with sr20 - $40 obo
1 redtop maf w/ pigtail - $40 obo
stock sr20 clutch - 30 obo
stock sr20 flywheel (needs turned) - $20
2 s13 sr20 valve covers - $40 obo each
s14 sr water pump - $20
2 s13 sr water pumps - $20 each
2 s13 sr20 chain tensioners - $30 obo each
2 s13 sr20 oil pans upper and lower - $40 each
2 s13 sr20 rear man seal plates - $10 each
2 s13 upper coolant necks - $10 each
2 s13 lower coolant necks - $10 each
s13 CAS - $50 obo
