F/S - S14 and Sr20det Parts - Good Prices - Check it out!
OK So im digging through my garage trying to get rid of stuff cause moving day is coming soon and I don't want to be dragging this stuff around any longer. So please purchase this stuff and put it to good use. All parts are located in Orlando Fl and are of working condition unless otherwise noted.
52mm gauge Pod for S14 A Pillar. - $15
1996 Manual S14 KA ECU - $25
1996 Manual S14 Sr20det Code "WC" - Sold
S14 SE gauge Cluster - SOLD!
Zenki Grill - SOLD
S14 Touge Factory 3" Cat-delete Down-pipe - $100
Greddy 52MM Boost Gauge - (Light is going dim) - SOLD
Greddy 60MM Electronic Water Temp Gauge - Needs new Sensor/Comes with water hose adapter- SOLD
Zenki Passenger Headlights - $25 each
SR20DET Red-Top Fuel Rail + 370cc injectors - $70
S14 SR20DET Valve Cover - SOLD
SR20DET Cam Angle Sensor - $70
SR20DET Ignitor - $50
SR20DET Starter - $50
Greddy Turbo Timer - $50
Zenki Driver Side Corner Marker - $20
Zenki Tail Lights - $50
Nismo Valve cover Oil Cap and Nismo Shift Knob - SOLD
KA MAF - #22680 40f00 AFH50-04 - $15
S14 SR20det 5spd Tranny - Works but no gurantee's came with a motor I bought but I never tested it. $100
I will Accept Paypal but add the 3% and shipping if need be. Cash and picking it up would work best, but if you're not local we'll figure it out.
Zenki Grill - SOLD
Not sure about the down-pipe Just know its spec'd as being the tightest fitting down-pipe for an s14 you can buy.
As far as the turbo timer no It is not plug and play. It requires wiring. You can buy the additional harness from greddy to make it a plug and play unit but thats a waste of money IMO.
S
