SR20det parts FS
s14 oil pump great condition 75
s14 lower intake 15
s14 intake cam 15
timing chain 5 each
lower timing gear 5
kouki chain guides 35
oem lifters set of 8 65
lifters modified for solids set of 8 100
rocker arms 5 each
valve shims(rocker arm pads) 1 each
retainers 1 each
timing chain tensioners 20 each
greddy RAS 45
oil drain for topmount(SS line, with fittings) 55
CAS broken plastic on the clip but works great 65
ARP main studs, out of box, brand new 65
S14 waterneck(great for s13sr guys that want to have easy access to water line 35
coilpacks 20 each
s14 speedo gear 20
ss ex manifold flange, for making your own mani 30
upper oil pan 35
lower oild pan 15
main girdle 15
oil squirters with bolt 3 each
hks wastegate actuator 75
rear main seal retainer plate 10
EX cam sprocket with timing gear 15
nismo slave cylinder 85
s14 lower intake 15
s14 intake cam 15
timing chain 5 each
lower timing gear 5
rocker arms 5 each
retainers 1 each
greddy RAS 45
coilpacks 20 each
s14 speedo gear 20
upper oil pan 35
lower oild pan 15
main girdle 15
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
