S14 Drift Car part out - Lots of Stock and Non Stock Parts!
S14 Drift Car part out - Holy Update Batman 56k Get lost!
Forge MotorSport Intercooler – $350
S14 Sr block – spun bearing on crank. block still ok – $150
S14 Sr20det Valve Cover with Nismo Oil Cap = $150
Tanabe Sustec s14 Underbraces used but still like new = $150.00
1 WC S14 SR ECU – $100
1 Redtop SR ECU – $75
Tein Tie rods and Ends + Spacers for more steering angle = $120
S14 Driver and Passenger front fenders black = $60 each or $100 for both
2 S14 passenger side door = $50 each
1 S14 driver side door = $40
S14 Sunroof = $100
1 s14 t-25 turbo – shaft play - $50
96 s14 to s14 sr20det WC ECU Wiring Harness Taylor Durdan Built - $300
96 s14 to s13 sr20det wiring harness Taylor Durban Built - $300
S14 Lower Harness Pinned for SR. = $50
1 Passenger side S14 Interior Door panel = $25
S14 rear seats (clean) = $20
2 S14 Sr 3" downpipes = $125 each
1 Greddy Catch Can - $65
S14 SE Gauge cluster - $50
2 S14 brake master Cylinder - $15 each
2 S14 brake boosters = $25 each
s14 Sparco Bottom Mount Seat Brace = $150
S14 Sr20det Side Mount Intercooler = $70
S14 Sub Frame - $75
240sx Sub Rame collars - $50
S14 Adjustable Rear TOE RODS knock offs - $ 60
S14 Gas Tank - $100
Sr power steering Pump no pulley - $100
Sr power steering pump with pulley = $120
2 Sr20det Cam Angle Sensor - $100 each
3 Sr20det complete Coil Packs and harness(4 coil packs + 1 harness) - $150 each
1 Sr20det Ignitor - $100
Sr20det Stock Exhaust Manifold - $50
S14 5 speed center console - $40
S14 rear bumper Black Great condition - $100
S14 Zenki rear tail lights - $60
S14 6 bolt axles - $50
2 s14 Zenki passenger side head lights and one extra lense - $50
s14 Zenki Driver headlight - Broken but with extra light to replace lense = $25
S14 SR20DET HOT-PIPE $40
S14 REAR DECK LID $25
S14 Power Steering lines includes all lines for s14 power steering = $100
S14 Shifter Boot = $30
2 SR20DET 5 speed Transmissions $250 each
2 SR20DET Starters = $125 each.
S14 sr20det A/C compressor and bracket = $50
s14 windshield wiper motor = $15
s13 sr20det Maf = $100
S14 Dashboard = free come pick it up. has some cracks but no to bad.
S14 head liner = $10
S14 sun visors = $10 for both
S14 Front Sub-frame = $25
Misc SR and KA A/C lines = $25 each
S14 ASH Tray =$15
S14 Zenki Passenger Corner light =$25
S14 Driver and Passenger Door Trim + 50mm Gauge Pod =$30 takes both + pod
S14 Drive Shaft Loop. = $20
2 S14 Coolant overflow tanks = $15 each
S14 Cluster Trim = $25
S14 A/C Control Trim = $20
96 Ka Speed ECU = $50
2 S14 Sunroof Switch with Lamp = $25 Each
Sabelt 4 Point Harness = $50
S14 Stock Radio Amplifier = $20
S14 Rear Stock Mud Flaps = $25 for all 3
Z32 Rear Uprights = $50
2 S14 Zenki Grills Both in ok Shape one is missing back tabs = $25 for the good one $15 for the not so good one
2 S14 Rear View Mirrors = $5 each
S14 Driver Window Switch = $15
S14 Sr20det Cooling Fan = $20
S14 Driver Side Mirror = $35
IF YOU PLAN ON PAYING WITH PAYPAL PLEASE ADD 3% to the item you wish to buy.
Updated!
email is Robd@stfuanddrive.com
phone number = 321-356-4577 call after 6pm on weekdays.
S14 Sunroof = $100
S14 Sub Frame - $75
S14 Gas Tank - $100
S14 ASH Tray =$15
Updated!
Block is completely disassembled. Number 4 Rod bearing took a shit and seized. Killed the crank and the rod but the block was fine.
do you want to sell me just the rods? give me a call at 239-699-4317. my name is tim.
(O=O/-180sx-\O=O)
(O=O/-180sx-\O=O)
