FS: SR20 stock parts... Updated!
**UPDATED**
Got a deal on a bunch of parts. Here's the parts that I don't need. I saw the motor that these parts came from and it was super clean, and very stock. Contact me through PM. Work in Clearwater, Live near Tampa Airport, go to QSL meet every thursday. See pics!!
S13 SR20DET Redtop Motor had rod knock and is disassembled. Crank will need to be turned or replaced, everything else perfect. Upper pan tapped for catch can return, lower pan cracked. One broken exhaust stud on head, one missing. Entire long block minus headgasket. SOLD
S13 SR SMIC (side mount) with ALL piping. This includes: SMIC unit with BOV, stock hot pipe, stock cold pipe, stock T25 intake pipe, BOV recirc pipe, and valve cover blow-by tube. All couplers included. If you have a "motorset", this is everything you need. Some clamps missing, smic braket and duct missing as well. SOLD
S13 SR 370cc injectors. Set of 4 purple top stock units. SOLD
S13 SR MAFS. 22680-52F00 stock unit. SOLD
S13 Alternator with bracket. SOLD
S13 stock T25 turbo with all oil/coolant lines, inlet/outlets, heat shield and manifold. SOLD
S13 SR intake manifold. Completely bare, great as a spare for polishing, etc. $25
S13 SR stock flywheel (clutch and pressure plate are free). Whole setup has 60k miles on it. Set looks awesome. $75
SR trans. This trans had 500+hp put through it. It hates life, but still works. 4th whines, and teeth on all gears are bent. Good for bellhousing swap. $50.
S13 SR radiator. Very good shape, stock unit and SR coolant hoses. SOLD
S13 SR HICAS pump and reservoir. $free.
Hey, I'd take the SMIC and also the SR MAF.
Let me know.
Thanks
Let me know.
Thanks
Driven Concepts, LLC
1101A East Hillsborough Ave.
Tampa, Florida 33604
813-236-4500
Monday - Friday 9am - 6pm
WE ARE DIRECT
Tein, GReddy, Buddy Club, Bride, Tanabe, K-Sport, Power Enterprise, etc......
https://www.tamparacing.com/forums/d...ml#post4905630
813-236-4500
WE ARE DIRECT
That's easy enough. PM me your number and I will give you a call.
Thanks
Thanks
813-236-4500
WE ARE DIRECT
813-236-4500
WE ARE DIRECT
Hello!
Hello!
