FS - Universal 2g, 420a parts, Universal aftermarket
All engine parts are from a 420A car. I don't own a DSM any more, and I need this stuff out of my garage. I'll entertain any reasonable offer, and will be happy to cut deals on multiple parts. I've got a lot of parts not in this list, so if you need something in particular that you don't see, let me know.
AEM CAI - Powder coated red, has a small pin-hole where the bracket meets the tube. Can be easily spot-welded, no filter. - $40
Alternator (30k miles) - $75
Sensors; Oil Pressure, Knock, IAC: $5 each
Water neck/spout with both sensors: $35
Front x-member $30
Horn - $10
NVT-350 Transmission mount - $15
Passenger side axle - $50
Windshield washer reservoir and pump - $25
A/C hard lines - $30
Fuse box cover (In-cabin) - $5
Fuse box cover (Under hood) - $5
PCV valve (200-ish) miles - $5
OEM Thermostats - $5
180º Thermostat- $10
Dipsticks $5, each.
98 ATX ECU - $80
97 MTX ECU - $80
Talon tail lights and center section - No scratches or cracks (Comes with all bulbs)- $80
420a Cylinder head (Flat, but should probably be rebuilt) - $50
Cam gears - $20
Coolant pipes (Water neck to heater core) - $10
Coil packs - $25 each
Gauge cluster bezel - $10
Cruise control switch plug - $5 (New, still in plastic bag from Mitsu)
Tan door trim - $15
Golden Eagle vacuum manifold (Has 6x 1/8" NPT vacuum nipples)- $30
Autometer #9117 tach adapter (Sold with Hahn PF units) - $40
Several items aren't pictured, if you require pics of anything not here, please let me know.
Front x-member $30
Horn - $10
Dipsticks $5, each.
98 ATX ECU - $80
97 MTX ECU - $80
Cam gears - $20
Tan door trim - $15
"Kid, If you call me 'bro' one more time, I swear to Christ you're going to find out what your left testicle tastes like."
I offer professional computer / network services and consulting.
Over 10 years of industry experience.
A+/Network+/Security+ Certified ; CISCO CCNA, Novell CNA, Microsoft Certified IT Professional.
Door sills. I couldn't think of the word "sills" earlier. They go under the door between the frame and the door itself.
Also - ALL THE MECHANICAL/ENGINE PARTS ARE FOR 420A POWERED CARS.
Sorry for shouting, but I've had something like 10 PM's asking if the stuff will fit 4g63 cars. The answer is - NO.
Bump
Bump.
PM's replied. I'll happily trade everything on the list (minus the head) for an EVO III 16g or an SSQV and 38mm WG.
SOmeone has to need Talon tails! It took me forever to find a set in perfect shape, like these are... $50 for both tails and the centerpiece.
Take 50% off anything in the list if you pick up this weekend.
(Come on guys, I need this stuff outta my garage!)
C'mon people, I want my garage back.
$250 takes everything.
Bump.
