Loads of DSM parts....
Holy Smokes!!! I went through my storage area and here's the misc Eclipse stuff I won't be needing. Apologies for the long list but maybe there's something in here you need. Photos of everything! If it's not in this list then I don't have it so save your time...all this crap is OBO too...
I'm located in Clearwater and would be happy to ship if it's cheaper than gas...which lately, might often be the case...
Current list as of Wednesday 10/20/2008 - Items sold will be removed from list...
2G ECU Manual Turbo - this was my spare so I would never get caught without one...$100
http://i296.photobucket.com/albums/m...t/IMG_2932.jpg
http://i296.photobucket.com/albums/m...t/IMG_2933.jpg
See it run - MVI_2337.flv - Video - Photobucket - Video and Image Hosting
EProm ECU - not sure if this has any turbo application but it did come with a turbo parts car I bought in pieces - Super Cheap if it's the real deal...$50
Per post by 97blackwidow this ECU is for 1995 Mitsubishi Mirage 1.5 (4g15 NA engine)...no mention of turbo applications...
http://i296.photobucket.com/albums/m...t/IMG_2145.jpg
http://i296.photobucket.com/albums/m...t/IMG_2146.jpg
http://i296.photobucket.com/albums/m...t/IMG_2147.jpg
http://i296.photobucket.com/albums/m...t/IMG_2956.jpg
http://i296.photobucket.com/albums/m...t/IMG_2957.jpg
http://i296.photobucket.com/albums/m...t/IMG_2958.jpg
http://i296.photobucket.com/albums/m...t/IMG_2959.jpg
ACT 2100 7 Bolt FWD Clutch, Disk and Stock Flywheel - a little scorchy but prolly holds 17x better than your old sloppy worn out Lindsay Lohan mutha...$100
http://i296.photobucket.com/albums/m...t/IMG_2130.jpg
http://i296.photobucket.com/albums/m...t/IMG_2131.jpg
http://i296.photobucket.com/albums/m...t/IMG_2132.jpg
http://i296.photobucket.com/albums/m...t/IMG_2134.jpg
http://i296.photobucket.com/albums/m...t/IMG_2135.jpg
Adjustable FPR New - Open package but never installed - tune-a-mundo!!...$25
http://i296.photobucket.com/albums/m...t/IMG_2960.jpg
http://i296.photobucket.com/albums/m...t/IMG_2961.jpg
http://i296.photobucket.com/albums/m...t/IMG_2962.jpg
GReddy Exhaust Temp Guage - Slight cosmetics as seen in pic - Complete except for the female fitting that threads into the manifold...$75
http://i296.photobucket.com/albums/m...t/IMG_2963.jpg
http://i296.photobucket.com/albums/m...t/IMG_2964.jpg
http://i296.photobucket.com/albums/m...t/IMG_2966.jpg
2G Master Clutch Cylinder - used but presumed good out of a parts car...buy this cheap...$20
http://i296.photobucket.com/albums/m...t/IMG_2156.jpg
2G Throttle Body - everything you see in pic - sensor and motors presumed good off parts car...$25
http://i296.photobucket.com/albums/m...t/IMG_2948.jpg
2G Exhaust Manifold - virgin except tapped for EGT sensor...$25
http://i296.photobucket.com/albums/m...t/IMG_2943.jpg
http://i296.photobucket.com/albums/m...t/IMG_2944.jpg
http://i296.photobucket.com/albums/m...t/IMG_2945.jpg
2G Intake Manifold - Clean and painted with some misc silver paint...$25
http://i296.photobucket.com/albums/m...t/IMG_2942.jpg
1G Intake Manifold...$25
http://i296.photobucket.com/albums/m...t/IMG_2155.jpg
http://i296.photobucket.com/albums/m...t/IMG_2154.jpg
4G63 Valve Cover - sandblasted it and found slight crack - buy this if you know how to weld about 2"...$10
http://i296.photobucket.com/albums/m...t/IMG_2930.jpg
http://i296.photobucket.com/albums/m...t/IMG_2931.jpg
4G63 Valve Cover - Completely intact but has quite the coat of black paint on it...oil cap included...$25
http://i296.photobucket.com/albums/m...t/IMG_2929.jpg
2G Coil Pack...$25
http://i296.photobucket.com/albums/m...t/IMG_2140.jpg
http://i296.photobucket.com/albums/m...t/IMG_2141.jpg
http://i296.photobucket.com/albums/m...t/IMG_2142.jpg
Ignition Transistor - I think these work on both 1G and 2G cars...$25
http://i296.photobucket.com/albums/m...t/IMG_2151.jpg
Wire Harness out of ??? car - presume turbo car as it came with a misc turbo setup I bought...cuts for AF computer leads me to believe we're on the right track...$50
http://i296.photobucket.com/albums/m...t/IMG_2148.jpg
Premium Factory Stereo out of 2G GSX - Will need to find unlock code from Mitsu or internets...$25
http://i296.photobucket.com/albums/m...t/IMG_1022.jpg
http://i296.photobucket.com/albums/m...t/IMG_1025.jpg
http://i296.photobucket.com/albums/m...t/IMG_1026.jpg
http://i296.photobucket.com/albums/m...t/IMG_1027.jpg
2G AWD Hub - I've had this since like 2004 so I can't remember if it's for front or rear - Brand new aside from some surface oxidation from storage...$50
http://i296.photobucket.com/albums/m...t/IMG_2925.jpg
16" Wheels and tires look nice on Eclipse - You'll like em! nice and clean - not sure what car they originally came from - almost look a little Pontiac-ish - tires should get you around for a while until you find some new ones...$100
http://i296.photobucket.com/albums/m...t/IMG_2487.jpg
http://i296.photobucket.com/albums/m...t/IMG_2488.jpg
http://i296.photobucket.com/albums/m...t/IMG_2489.jpg
http://i296.photobucket.com/albums/m...t/IMG_2490.jpg
http://i296.photobucket.com/albums/m...t/IMG_2491.jpg
Pic on my 2G http://i296.photobucket.com/albums/m...opi2005001.jpg
2G Starter FWD - presumed good off parts car $25
http://i296.photobucket.com/albums/m...t/IMG_2951.jpg
Misc Relays around here somewhere too - let me know what you're after...$10 each
Foggy Hazed Headlight - Passenger side I think $10
Misc Auto Meter Oil Pressure Guage - looks electrical, not tube...$10
http://i296.photobucket.com/albums/m...t/IMG_2928.jpg
1G AC Expansion valve - New never used...$25
http://i296.photobucket.com/albums/m...t/IMG_2924.jpg
2G Cruise Control Servo...I just never put it back in...$25
http://i296.photobucket.com/albums/m...t/IMG_2935.jpg
7Bolt Oil Pan with return tube...$25
http://i296.photobucket.com/albums/m...t/IMG_2321.jpg
7 Bolt Windage Tray...$10
http://i296.photobucket.com/albums/m...t/IMG_2952.jpg
2G Turbo Head and Cams - every valve is bent - lifters didn't tick - cam sensor included...$25
http://i296.photobucket.com/albums/m...t/IMG_2946.jpg
http://i296.photobucket.com/albums/m...t/IMG_2947.jpg
More to come if I stumble across something...stay tuned!!
2G Coil Pack...$25
Hmmmm - thought I was blowing them out at $100 - tell you what, bring me $75 and a case of beer and we have a deal!!! Bud is fine...
Added: Greddy EGT, Adjustable FPR, pics inside that eprom ecu...
Thanks for all your awesome response! PMs returned
bump for you,thanks for the trans,it was perfect.
When you think you know everything there is to know,thats when you start to learn.
Chip Foose
http://www.teamrip.com/
http://www.importperformanceparts.net/
Chip Foose
Thanks for waiting - I was out for the weekend - All PMs returned!
Pending items are now highlighted yellow...I'll wait a bit but window shoppers beware...
Stereo was taken out of my 2G personally - don't know if it had been swapped before that or what...reduced price to $25...c'mon down!!!
Stereo is from the early model 2G-A Eclipse/Talon Turbos (95-96 model years). The 97-99 model year turbo DSM's came with a revised double-din Infinity headunit. Speaker sizes are all the same from the 95-99 turbo models though.
Another difference between the 2G-A and 2G-B, is the wiring harness used for the CD changers in the trunk. The 95-96 came with 6 disc changers, while the 97-99 model years came with a 10 disc changer. The 95-96 model year double-din Infinity head unit, will work with a 97-99 turbo model Eclipse/Talon. The only thing that will not function, is the disc changer in the rear. The wiring harnesses are basically all the same though, so it'll plug right in.
"Even through the darkest days, this fire burns, always"
