FS: 420a & DSM performance parts
Im selling some unused items from my 420a engine project aswell as old 1g DSM project.
Stainless steel shifter base bushing kit(will fit all year DSM's and 3kGT's aswell). Brand new never used. = $25
Stock 420a Throttle body (perfect for porting or having bored) = $25
Stock 420a intake manifold (perfect for 8 injector set ups or port polish jobs) = $25
New DSM Turbo cooling factory hard line. = $20.
Frankenstine Level 3 Turbo (modified 20g/garret). waistegate removed and fully ported. I do not have specs however it was on a 355hp DSM for a few runs. It is clean with a smooth spinning shaft and very little play. Bolts right up but requires an external wastegate). = $400
Tial 38mm wastegate never mounted brand new in box. = $220
Apexi N1 3" Inlet Black can New in box never used = $225
I personally believe they do. Scince you can use an actual relacement Bulb with these you can upgrade the bulb itself to a better quality rather than relacing the entire glass unit with another regular glass unit. Theres a different reflection pattern also that make light reflect better than stock.
When ET dosen't fly a spaceship he drives a DSM...
