Parting Out: crashed my si parting out a lot of parts gsr swap and more
Old Feb 10, 2011 | 02:51 PM
the_third_lobe's Avatar
Thumbs up Parting Out: crashed my si parting out a lot of parts gsr swap and more
VIN # 1HGEM1150XL091209
obd-2a (99-00) to obd-1 jumper harnesses (bought from LHT its the one plugged into the ecu) $50
oem honda ek coupe front and rear mud flaps $100
dsm 450cc injectors with resistor box $125
ek gauge pod with glow shift oil pressure boost and coolant temp gauge come with all sensors $100
skunk2 lowering springs $100
2.5" cat back exhaust $100
spc rear camber kit $100
act clutch and pressure plate $200
a bunch of other random parts that i have for sale
greddy type s blow off valve comes with bov and aluminum weld on flange $150
ek hub $10
wet nitrous nozzle $10
turbo oil drain flange $10
autometer tach $30
new hondata 3 bar map sensor $125
cometic b series exhaust manifold gasket $25
t3 - t3 38mm wastegate adapter $30
digital msd window switch $100
aluminum 38mm wastegate flange $10
dei cooling bulb $100
new karcepts rbc throttle body adpater $75
new billet throttle cable bracket for K series $40
new oem honda throttle cable for K swap $50
mild steel tial 50mm bov weld on flange $10
fuel pressure regulator $20
OBD2 SOHC dizzy $30
stock k shifter box $50
buddy club shifter box $80
stock type s intake manifold $50
stock ls intake manifold $10
used k20 hondata intake manifold gasket $40
rev hard intercooler $100
rev hard intercooler $75
new golden eagle cam gears B series $180
40mm wastegate $75
Old Feb 11, 2011 | 06:25 AM
Old Feb 11, 2011 | 08:27 AM
NinetySix_EK's Avatar
FTM- Los Baja Pantis
Bump for nice parts!
Wire & Brake line tucks Engine & Transmission Rebuilds Motor Swaps
Wire Harness conversions Turbo & Nitrous installs any application add-ons
→Valve Covers →Engine Bays →Hoods →Rims.
LOCATION
Deltona
321-420-3204
Old Feb 11, 2011 | 08:36 AM
joshjdmef9's Avatar
bummppp
Old Feb 11, 2011 | 10:43 AM
Old Feb 11, 2011 | 01:49 PM
phil04's Avatar
I need that ecu and conversion harness. Will send a pm.
Old Feb 11, 2011 | 01:54 PM
pm returned
Old Feb 11, 2011 | 04:52 PM
gsr is sold
Old Feb 11, 2011 | 07:48 PM
Side skirts are sold
Old Feb 11, 2011 | 08:14 PM
Ls_[eg]hatch's Avatar
mowchowbrowncow
Good shieet! ^ shoulda take them down cause like 99% of tr wont notice.
