Bc Parts Need Gone Asap Only 16 Miles On Them
Old Oct 6, 2009 | 08:29 AM
xxWTFxx's Avatar
Default Bc Parts Need Gone Asap Only 16 Miles On Them
ALL PRICES FIRM
2000 integra front seats $80 for both good condition (tan)
integra ls cluster reading ZERO miles $100
74mm throtal body $120
two front coil overs $40
LS crank $80
type R pistons $150
power stering pump $70
fully built drag racing LS head / $1000
bc 404 cams
bc cam gears
bc stainless steel oversized valves
bc Titanium valve seats
bc dual valve springs
bc TITANIUM retainers
(9.7 of 10) 3 Reviews
Brian Crower Stage 3 Cams
Brian Crower high performance camshafts are ground on state-of-the-art CNC cam grinders to insure accuracy and tolerances to within .02mm. Every BC camshaft profile has been prototyped and dyno tested for proven horsepower results prior to placed into mass production. By grinding cores in high volume, Brian Crower, Inc. is able to pass the cost savings on to the end user. Quality at an affordable price.
Stage 3 Features:
- Longer duration profile.
- Added RPM potential.
- Intended for fully built engine.
- Tuning and ECU mods recommended.
- Requires upgraded springs and retainers.
Crower Cam Gears for the Integra
Crower's new cam sprockets are made from premium 6061-T6 billet aluminum and incorporate a four bolt ARP fastening system to prevent the slippage found in other brands. For the ultimate tuner, Crower sprockets feature 5/16" diameter, 12 point ARP fasteners with a hardened washer to prevent galling and stripping. The lightweight design reduces unwanted harmonics which could cause valve train failure. Price is per cam gear.
Brian Crower Stainless Steel Valves for the Integra
BC valves are made from premium stainless steel with a black nitrate finish, fully machined and swirl polished for ultimate air flow. Dished head for added weight savings and increased valve control at high rpm. Standard and oversize head available.
(9 of 10) 2 Reviews
Acura Integra VALVE LOCKS TITANIUM 5.5MM
Brian Crower Valve Springs for the Integra
Designed for high rpm, BC valve springs are wound from only the highest grade, super clean, chrome silicone alloy and feature proprietary processing procedures (chamfer, debur, etc...) for consistent pressures over long term, high rpm useage. Quality valve springs are critical in the prevention of premature valve float.
(10 of 10) 1 Review
Brian Crower Titanium Valve Spring Retainers for the Integra
These retainers are lighter and Brian Crower rates them as three times stronger than stock. If you already have the HKS valve springs or are building a custom setup, these are just the retainers for finishing the job!
(10 of 10) 2 Reviews
