D&B Series Parts FS
D&B Series Parts FS
Doing a LS swap in my '93 EX coupe so I dont need this stuff and I also have some crap just lying around
All parts are OBO so make offers as long as they arent retarded
Best way to reach me is by phone 352-812-0437
D series Parts from '93 EX coupe
-Trans off a '93 Z6 motor only 70,000mi no grinds $100
-Clutch looks like maybe 10,000 on it OEM $30
-Trans off a '93 Z6 w/ 185,000mi grinds 2nd $25
-D16z6 Shortblock 185,000 no wear on cylinder walls bearings are worn but not spun had a slight tap when pulled $40
-z6 head might be cracked? not sure? $20
-All motor mounts $30
-shift linkage $40
-Axles $35 each
-Halfshaft $40
-Other parts im not thinking of
B series stuff I got layin around
-OBDII Head low miles $40
-OBDII Intake mainfold slight port job $30
-OBDII injectors w/ 111,000mi $40
-OBDII LS wiring harness $60
-OBDI P75 ECU $70
-OBDII crankshaft position sensor $40
EF OBDI LS swap parts
-ebay swap mounts got like 15,000mi $40
-wiring harness plugs into OBDI engine but fits OBD0 plugs at fenders. ALL connections soldered and heat shrinked. Didnt pull a single check engine light and has separate plug for extra wires that need ran to ECU. still hooked up to the ECU conversion harness but can separate. $60
-ECU conversion harness OBDI ECU-->OBD0 plug $60
-shift linkage $40
-Axles $35 each
-Halfshaft $40
-OBDI P75 ECU $70
it doesnt look cracked but I had oily residue in the coolant and the head gasket looked fine. Never had any problems with it overheating and never hydrolocked from coolant in the engine so? I dunno maybe I'm just giving somebody a really good deal
still have the clutch and 2 flywheels number is 352-812-0437
