tons of parts for sale turbo, nitrous, ecu, fuel, head, valve cover pictures
brand new precision sc62
billet compressor wheel
.70 compressowetr
.83 turbine
t3 turbo flange
4 bolt down pipe flange
2.5 inch compressor outlet
4 inch compressor inlet
$1100
wet nitrous kit with msd this kit is 100% complete with everything you need to install it. $400
10 lb bottle
bottle brackets
brand new main line
fuel solenoid
nitrous solenoid
all an fittings
short lines
fuel tap
nozzle
msd rpm activated window switch
2 relays
micro switch with bracket
master power t3/t4 turbo .50 compressor .48 turbine 5 bolt downpipe flange $400
t3 to t3 adapter with 38mm flange $30
5 bolt 3 inch downpipe $80
b16 crank $50
[IMG]http://i439.photobucket.com/albums/qq117/k20tek/6.jpg[/IMG
gsr intake manifold $50
si rear disc conversion $200
b series power steering pump $50
si headlights $50
blow off valve $50
blow off valve $40
b series cast manifold $100
WTT uncut jdm red Vtec valve cover for any other dohc vtec uncut valve cover
complete h22a4 head $350
comes with the complete head fully assembled
valves
springs
retainers
cams
cam gears
valve cover
dizzy 0bd2
injectors
fuel rail
intake manifold
tb
vtec solenoid
brand new B&M fuel pressure regulator thats already assembled. $60
LHT vacuum port $25
rywire obd2a to obd1 harness $65
will fit
• 1996-1999 Acura Integra
• 1996-1998 Honda Civic
• 1996-2001 Honda Prelude
• 1996-1997 Honda Accord
mint chipped p28 with chrome and data logging port
$150
.70 compressowetr
.83 turbine
t3 turbo flange
$1100
10 lb bottle
bottle brackets
brand new main line
fuel solenoid
nitrous solenoid
all an fittings
short lines
fuel tap
nozzle
2 relays
b16 crank $50
si headlights $50
blow off valve $50
blow off valve $40
valves
springs
retainers
cams
cam gears
valve cover
dizzy 0bd2
injectors
fuel rail
intake manifold
tb
vtec solenoid
LHT vacuum port $25
will fit
$150
