few good parts/engine parts zex kit rota's piston kit engine block
Old Apr 7, 2007 | 05:20 AM
DOHC16CRX's Avatar
CARPET GUY
Exclamation few good parts/engine parts zex kit rota's piston kit engine block
I have some shit that i am trying to get rid of.
1. NIPPON RACING (npr) 81.5 MM PISTON KIT.These are new in the box w/ npr rings and wrist pins.They are jdm p72-00 pistons and are stamped p72-00 on the pistons.These pistons in an ls/vtec make is 1830cc.ALMOST 1000 more cc then gsr.I had 2 sets and this is the last set.These can handle 400+ hp. looking for $150 SOLD !!
2. I have a complete set of standard(green) ACL bearing set.Comes with rod,mains and thrust.For any Itr/gsr b18c.They are all new in the box. $85 for the set. SOLD !!
2. ACL new in box Standard size(green) mains and thrust for itr/gsr b18c.$50
3.96 b18b block.comes with rods,main caps w/ bolts only.Might have a few more to it.Needs cleaned up and bored to atleast .25 over.Its standard 81mm now.It just has some cylinder rust from sitting.PERFECT BLOCK FOR THE 82MM PISTONS. Looking for $150
3.99 itr throttle cable.Mint like new $20
4. Complete zex DRY KIT 82011 kit with everything extra included.Comes with a new in box zex air filter that sprays right into the filter.New arming switch.I have jets for a 55,66,75,100,125 shoot.Comes with all steal lines.16' for the bottle,6' for the air filter,6' for the nos gauge,18" for the purge kit.I have every fitting and line.Nothing needs to be with the kit cause its complete.The bottle is zex.It has some scratches but i have a new zex black bottle bag that makes it look like new.Bottle bag is new in the box as well.I also have a billet bottle bracket that stands the bottle up side ways.I payed 160 for that but will include for extra 100.It is a bad ass bottle bracket.The zex brain box also has some scratches but all works 100% perfect.Everything extra is new in the box never used.I also have a install
book.Looking for $250 for everything w/ out the bottle bracket 350 with it.Will also throw in a new fire ext.
5.New set of rota slip streams.I bought them new and used them for 60 miles.They are MINT.NOT EVEN 1 HAIR SCRATCH.They weigh in at 12 lb
ea. They are gun metal.I even have all the little center caps.Right now they have New 205/50/15 reg. tires on 2 of them and the other 2 have brand new G-FORCE DRAG RADIALS W/ 60 MILES ON THEM. I bought the drag tires new for 150 ea. and the other tires were 70 ea. so i have 440 just into the tires.I am looking for 650 w/ tires and 350 w/ out tires.
6.crx nuespeed strut bar.upper (red) $40
7.Itr valve cover.Has cut cam gears but was powder coated crinkle red after the cut for the gears so it looks great.I use it for a few months so its still like new. $85 SOLD !!
8.ACT CLUTCH KIT. This is for a Cable B series tranns.I used it for maybe 6 months so its still like new.Has the extream H025 pressure plate,street/strip clutch disk and new throw out bearing.I should even still have the box for it.This will work on a cable b16a or b18's.Will fit all 90-91 integra ls,gs.This CLUTCH disk will not fit YS1.Pressure plate will fit any B series.This is a $450 clutch kit.I am looking for 225 firm ! SOLD !!
9. I also have a ACT 12.5 LB flywheel that needs to be resurfaced.I have had it for years and i am kinda tired of looking at it.first 60 picks her up.This will fit all B SERIES. Cable or hydro.
10. 8.8 LB B-series flywheel.This is the flywheel i use.I put like 40 miles on it.I just had alot of work done to it.Just had a resurface.I had it 100% balanced.You can see all the markings and the drill holes from the balance on the back side.I payed 70 just for the balance and 40 for the resurface.This flywheel is perfect for 8500+ rpm's and you will know for sure all is balanced to the T.I have receipts from all the work.I have all my machine work done by CEDRIC at Modern Performance in largo. 150 firm
11.Turbonetics t3/t4 manifold and down pipe for any 94-01 integra.This manifold is set up for A/C !! This is vance's old set up.I never used it sence i bought it from him.This is in 100% mint condition.No dings,dents,rust or any of that.The down pipe is also flawless.Not even a ding in the bottom.It has been high temp JET COATED.(black)(manny and down pipe).Uses a 38mm tail waste gate.This will bolt on your stock or aftermarket exhaust.The flange will match right up sence it is made for DC'S.This came from 1 of the $3000 bolt on turbo kits they they sell off the web site.You would spend around 1k for the manifold and down pipe from turbonetics.I have around 450 into it and would like to get 300 back out of it.I know vance said he didnt even use this for very long at all so its like new and clean as hell. Make me an offer OR trade.
12. Log style series t3/t4 manifold only.Uses a tail 38mm.This is a nice looking manifold.Looks very well made and thick.Its brand new and never used.Not sure of brand.Will work on all B series motors.
13. Complete GSR b18c gasket kit.This is the top and bottom end kit.Every gasket for the WHOLE engine is in this kit.All i used was the head gasket so thats the only thing not included and they are only around 30 bucks.I would be typeing for ever if i listed all thats included.Every thing is sealed and never opened.Has every gasket from the oil pan to valve seals.Will work on all B18c1 or 5 and b16a.If you need it for b16 or itr i have a new intake gasket cause gsr is differant but thats all and every thing else is the same.Looking for $80
14. 99 itr oil pump.I have been holding on to it for about 2 years and i dont think i will ever use it so its gota go.
15. oem acura p72 vtec solenoid gasket/screen.They are like 23 or so and i want 15 for this 1.Its unopened. SOLD!!
I am kinda getting out of all this.My back can not handle any more working on these dam cars.Lots more to come.I will post as i run across it all.I have lots more shit that needs to go.
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
Old Apr 8, 2007 | 04:00 AM
DOHC16CRX's Avatar
CARPET GUY
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
Old Apr 8, 2007 | 05:22 AM
Teggy02's Avatar
Drive It Like U Stole It!
great prices mang! get up there^^
1989 Honda CRX SI (222,000 miles) sold
1994 Acura GSR (168,000 miles) crashed/sold
2002 Acura RSX S (127,000 miles) *Work in progress*
hero.
http://www.youtube.com/v/17XBW5OZdOM&hl=en&fs=1
Old Apr 8, 2007 | 08:09 AM
JDMjunkie's Avatar
is the nitrous kit a wet or DRY kit???
TampaRacing's DEAD!!
Old Apr 9, 2007 | 08:51 AM
DOHC16CRX's Avatar
CARPET GUY
Its a dry kit 82011.I also have the zex filter with it that sprays right into the tip of the Air filter.Its pretty tight and it make it where you cant see the nos nozzle.They say it cools the shit out of the air and ad's some hp.I have pics if needed.
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
Old Apr 12, 2007 | 06:13 PM
DOHC16CRX's Avatar
CARPET GUY
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
Old Apr 12, 2007 | 06:20 PM
pieromarr's Avatar
oh mai gawd
clean up your pm it said when i sent you a pm
Old Apr 12, 2007 | 06:23 PM
MazdaMX3Freak's Avatar
Vtack THIS!!!
you wouldnt have a 96-2000 tegg wiring harness would you?
-2008.5 Mazdaspeed3 CWP
Old Apr 12, 2007 | 07:54 PM
DOHC16CRX's Avatar
CARPET GUY
yes i do . Its a 96 obd2 ls.has a few cut wires but they are just sensor . Harness is like new besides that . make offer . I JUST CLEARED PM'S. SORRY GUYS
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
Old Apr 12, 2007 | 08:27 PM
streetlegends's Avatar
STREETLEGENDS!
will that oil pump fit a 95 gsr if so how much?
