SBC parts F/S
MSD digital 6 - 200$
MSD ProBillit Distro. w/ bronze gear - 180$
Bronze Distro. gear - 30$
Blaster2 coil - 20$
March underdrive pulleys (crank, wp, alt) - 75$
Holley Blue FP - 40$
Moroso Ultra 40 wire set - 80$
any questions PM me. Tyty.
Blaster2 coil - 20$
RIP Kevin C. Gonzalez; Miss You Brother.
Bowtie Block .30 over
3.875 Callies magnum small rod journal crank
Carrillo 6" srj Rods with edm oiling holes and 3/8 carr bolts
Plasmamoly rings .30 over
H bearings std. std.
JE forged flattops. ~12.7:1
Brodix -10 2.08/1.60. Fully ported.Tit. vavles, springs and retainers,springs good to 700 lift
Single plane air gap style manifold.
850 mighty demon
.630/.630 264/272 111 solid roller.
comp cam magnum 1.5 roller rockers and stud gurdle
Double roller timming chain
Internal Flexplate and ATI dampner
7qt. deep allunimun race pan w/ milling high flow oil pump.
0 passes only break in miles only
7200$.
Fully built th-350 w/ shift kit. 500$
J&W 4600 Stall. 250$
Blaster2 coil - 20$
tranceadd_ikt@yahoo.com
813-541-9057 ask for mikey
there u go mikey..how many times do i got to tell u son..if your going to do it do it right..
ps,the heads are a nasty set of heads..i made 2.2hp per cubic inch when i had them on my 331sbc
850 mighty demon
7200$.
Blaster2 coil - 20$
This would also help if it was posted in the gm forsale forum
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Largo fl 33773
MV#72427
damn u mikey..
for every one to know the engine was built by acme racing..it could be a nasty 2 stage n2o engine..the crank can take 1600hp and the rods will hold 1600hp they have 3/8 carr bolts(400$ option and edm oiling holes another 400$ option) rods and crank alone cost 4gs and the heads to remake would cost u 4,500$
this is a nasty setup.if u dont believe me on the prices.i will give u numbers to carrillo and callies and list out the head parts..from what i figured the engine makes around 675hp and could take 2 300 shots easy.
