fs 4.6 parts and mach 1000 subs and amps
1. x pipe for long tubes 80.00 used for a day
2. spec two peice flywheel. 150.00 hundred miles on it.
3. pi motor 21 lb injectors 50.00
4. 19 lb injectors 40.00
5. 96 non pi mass air meter 60.00
6. pi mass air meter 80.00
7. two air filter adapters 15.00 ea
8. mach 1000 factory amps amd subs. dealer add-on system. 300.00 firm sounds awsome will work on ant mach 460 system.
im might have more will add as i find. if you need pics text me at 727-946-7903 mike
MlwMike
MlwMike
i'll give you a plate of meat spears for the x-pipe
target shopping cart... yeah its quick
06 busa, not as quick as the cart
09 G8 GXP quicker than the busa but still slower than the shopping cart
Mike i still have that adjustable fuel pressure regulator and some steeda pullies if you are interested. I may be interested in flywheel if i could get some more info on it. Part number ect so i can figure out weight ect
seventhgear
8
05-21-2006 07:46 PM
