mother load of aftermarket parts
I won't take anything less than what I post,prices are low enough.I will not hold anything for anyone,been screwed before too many times.
built 8.8,4 lug,5/8 studs,stock fox width,Moser 33 spine spool,axles,c clip elminarors,spherical bushings,ta girdle,390 gear but a few teeth are broke happened towing it the pinion nut came off.$500
4 lug Bogart D10s,have three,one rear is 15x10 drilled for rim screws.One front is carbon fiber wrapped and the other front is is polished.was planning buying other rear and having all carbon wrapped.$450
AJE tubular kmember and a arms,no motor mounts,tow hook and travel limiter welded on,freshly powder coated wrinkle black.$400
New CHE 8.8 rear end brace,powder coated red,bolt in design $125
New UPR 79-89 caster camber plates.$100
New RCI platinum 5 point cam lock pull down harnesses(2)outdated $125
New Optima red top $75
New AED carb throttle cable bracket,has return spring setup.$50
New CSR carb throttle cable bracket $40
Anodized red fuel log $30
2 inch aluminum carb spacer $20
New MSD blaster3 coil and bracket $30
MSD rpm box $20
New Lokar adjustable throttle cable $50
New Holley carb regulator $10
New 1000+HP intercooler,big,three inch in and out $150
New Taylor spark plug wire boot protectors,silver (eight) $50
MSD rpm box $20
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
I want the Lineklock, and the cutoff... does the CHE brace have bolts ect with it? Just drill and bolt in?
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Need some cash brother,I found a bike I need to pay for lol I might go by Johns tommorow,if I do ill give you a call.
sorry brother,just sold the battery cut off and brace,line lock is yours,thought you guys were coming by to look at the car?
