5.0 mustang flowtech x pipe for shorty headers,same as dr gas style
bought this to put on my car,WILL NOT FIT cars with tremec 3550/tko trans,the x is directly under the trans,the 3550 is larger than the t-5,will only fit with t-5.these pipes have a unique sound the same as dr gas x-pipe.air injection pipe has been totally removed and welded shut.still has holes for o2 sensors in good shape,comes with hardware$75 obo
88 mustang hatch
holley 650dp carb,175 shot nos,3g alt,underdrive pulleys,strut tower brace,tko trans,bbk x-pipe,2 chamb. flows,jet coated shortys,urethane mounts,tri-ax shifter,moroso 7 qt pan,msd wires,sumped fuel tank,twin holley blue pumps,alum.driveshaft,axle brace,billet bearing caps,tru-trac diff,fms gears,solid pinion spacer,moser axles,smog pump delete,msd 6al,cobra brakes,roller thrust plate,f cam,stealth intake,ported track heat heads,lots of other crap i cant remember.
88 mustang hatch
yes,its bolt on,it has the holes for the o2 sensors,there are plugs screwed into the o2 sensor holes,the o2 sensors arent included,just unscrew the plugs and screw in your o2 sensors.
88 mustang hatch
88 mustang hatch
im in ocala,but i will be down in tampa area this sat,ttt
88 mustang hatch
88 mustang hatch
ill get some pics later tonight when i get home from work,but here is what it looks like new mine just has the air injection pipe removed
88 mustang hatch
88 mustang hatch
88 mustang hatch
88 mustang hatch
actual pics much nicer set up then example pic...IMO...pssssh...and for $75! GREAT PRICE!
Here is a example of the Dr.Gas set up... same design as yours (as he said...) and waaaaaayyyyy le$$... Dr.Gas cost $209.00
http://drgas.mybisi.com/product/must...hortie-headers
2012 Mustang GT 5.0 "COYOTE"..."TAMPA STOCK"
sold
88 mustang hatch
88 mustang hatch
