trick flow track heat
im selling a upper and lower trick flow track heat with 70mm polished throttle body 70mm EGR spacer,30lb injectors,73mm C&L mass air meter for 30lb injectors.also a home made air intake with filter and bracket for the C&L to blot down to the car.also comes with a fuel injector harness and fuel rails. im asking 650.00 cash this stuff new is over 1000.the bolt on the upper is not the right bolt could not find the bolts so i used that one just to hold it together.if you have any questions please ask
^ I would love to go that route myself...But... The lil 5Oh should do me well the direction I am going also... ***
for now ***
2012 Mustang GT 5.0 "COYOTE"..."TAMPA STOCK"
i only went with the 351 because i already had a 347 and it dont hold up.or should i say it lasted for about 2 years.make 510@wheels and 602 tq but the stock 302 block is to waek.
