BBC parts and blocks, 7.5 rear chevy, 351 torker 2 and more
I know these are mosltly chevy parts but you guys might know somebody who wants to build a hybrid
(2 sets)454 Mark 5 Rotating Assemblies
Cast Crank, 3/8 rods, flat top pistons, complete factory roller cam setup 330 hp marine cam), windage tray, Main caps with bolts, oil pan, timing cover, oil pump with pickup, timing chain and gears,
00 parts not cut or overbore
Mark 4 tall deck block bored .60 over
forged pistons, 4 1/4 forged steel crank, rods not included
2 4bolt and 1 2bolt seasoned mark 4 blocks
Nascar 4 bolt main .30 over 350 high nickel block, fully polished, studded, plugged, and drilled
Mark 5 454 00 bore block, forged crank, 7/16 rods, balancer, oil pan, oil pump, timing cover, gear and chain, roller cam,
4th generation 7.5 inch rearend with 4.10 gears, auburn posi, needs spider gears
2 350 edlebrock performer intakes and 1 351 ford torquer 2 intake
2 sets of rebuildable mark 5 rectangluar port heads
Complete marine volvo penta 4.3l motor with all accessories, 0 hours block freeze damaged
All parts are located in Bradenton FL. 941 755 7035 call during mon-fri 9-5 ask for mike
leave message if calling after hours. Best offer welcome no trades
well being I am not too good and heavy into chevy builds just yet, I am building a truck that I have always been in love with, its a 68 chevy short bed and I want to put a big block 396, 454, or 502 or something along those lines that will run good and sound nasty, I am not racing this truck at all I just want the balls to be there with the touch of the pedal and be able to blow off the rear tires for some good ole smoke action whenever I want, sooo, I guess what I am askin is what would it cost me and does he have the parts to build me a drop in 400 to 500 hp big block with the things you have posted? and maybe does he have a tranny to with it? just looking for some info on this stuff anything helps at this point. sorry if its a dumb question. thanks man
Thats one sexy ass saleen
Good motors are built at or closely using a machine shop. I would talk to a builder and tell them your goals. Big blocks make a lot more torque than small blocks so that is the number you need to look at instead of hp. You should build your own big block and these parts are a good place to start. Plus these guys are selling this stuff super cheap. Call Mike and ask him about a drop in motor. He has a couple good machine shops he could get you in touch with.
