The HUGE Partout!!! lots of 5.0 performance parts AFR heads much more
The stang is getting parted.....
All motor parts have less then 100 miles on them unless otherwise stated
AFR 185cc heads(cnc ported to flow 225cc intake side, 185cc exhaust side)Trick flow 1.6 rockers, 1.6 springs and pushrods $1500
Parker funnelweb intake manifold (port mached to heads)$250
Full Msd everything(Dizzy,plug wires, msd 6a box and coil)$400
Steel rotor made for hydraulic roller cam
Comp cam xtreme energy camshaft $150
Art carr racing aod tranny(less then 1000 miles) $1600
Aluminum drive shaft $100
Drive shaft loop $75
Holley carb with proform main body, throttle plate, and metering blocks $600
342 stroker bottom end full forged everything 10.5:1 compression
milodon oil pan and oil return go with the motor ford motorsport high volume oil pump $2200 obo
B&M hammer shifter $125
have monster tach, speedo, shiftlight and oil pressure, volts, tranny temp, fuel level and temp gauge.if u want any of these let me know ill let go for cheap.
full interior let me know what u want out of it
chassis is going seperate has steeda lowering sprins, 5 lug conversion, and 3:73 rear end gear, and full gripp k-member...make offer on chassis
thanks for not returning the PM..........
were did you have the heads ported and what would you sell them to me for with out therockers and push rods?i will would like to use them on my 358 windsor that i am building.and those 1 3/4 headers are they for a 302 or for a 351w?
