Dodge Ram 4.7 5 Speed Transmission Swap $400
This is a complete five speed two wheel drive manual transmission swap for a Dodge 4.7. These items were removed from a 2003 Dodge Ram 1500 with a 4.7 engine and were in good working order when they were removed from the vehicle. This swap should fit many different years of the Ram 1500 from 2002 and up. You get the transmission, flywheel, clutch, pressure plate, disc, pedal assembly, clutch master and slave cylinder with line, shifter, shift boot, center console, manual transmission computer and harness, driveshaft, etc. This should be everything you need to convert your automatic Ram to a manual transmission truck.
