do you guys have hptuners?
it is a 2004 sunfire i was running a t28 on 32lb injectors running 8-9 lbs i switched to a t/3 t/4 running the same boost it is currently on a street tune with hptuners the issue i have is i do not own the software do you have the program? it basicly needs a slight fuel remapping due to different rpm/boost spool range will probably run too rich at low rpm
