Welding & Fabrication
Old Feb 2, 2009 | 07:37 AM
NeKe1point0's Avatar
Exclamation Welding & Fabrication
All welding done inhouse using Miller Synocrowave 250.
Please contact us via PM or our shop forum for any fabrication questions/quotes.
Thanks
Check our shop forum for up to date fab work !
Some examples of different materials:
Stainless steel:
Aluminum:
Old Aug 7, 2009 | 09:20 AM
Custom Exhaust manifold:
Aluminum Charge piping:
Some recent fab on a Lex =)
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
www.ProvenPowerTampa.com
Old Oct 3, 2009 | 05:46 AM
SRT4 dumptube fab
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
Old Oct 3, 2009 | 05:48 AM
The coupe came in for some work yesterday. The goal was to modify the charge piping to accept the new traction bar. What seemed like a simple fix turned into a major PITA Here are some before pics of the routing and how it was run:
After some measurements and some thinking we decided to start with cutting the turbo housing
Then we welded a 90deg mandrel bend and reinstalled the housing.
We HOPED we would have been able to clear the original oil drain but unfortunitly the elbow pointed directly at it. So the now modded housing now required the oil drain to be changed.
After the drain was relocated it was on to the charge piping...
Now the traction bars could be installed and the dumptube fabbed and routed for exhaust evacuation The dumptube material was sourced from a previous setup.
InsaneCivicCoupe returned to finish his 4" exhaust. From the shift linkage back was done in aluminum for weight savings. Here is how the car came in.
Some pics of the welding and fab !
Resonator before:
After with Vbands welded:
Pics of ground clearance:
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
Old Oct 3, 2009 | 05:49 AM
H22 Accord full 304SS exhaust
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
Old Oct 13, 2009 | 10:58 AM
#1rudebwoy's Avatar
nice work
Ah idiote ting dat !!!!!!!!!!!!!
Old Oct 27, 2009 | 06:47 PM
Built LS Vtec Dumptube
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
Old Mar 25, 2010 | 05:02 PM
Finally, we went ahead and heat wrapped everything for safety and lower underhood temps
Now with dumptube
Weld and clearence pics
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
Old Jan 26, 2011 | 04:57 AM
trudaturbo's Avatar
automatic 91 da turbo
nice
Old Jan 27, 2012 | 07:34 PM
03civic's Avatar
how much for u to make me piping for my turbo setup for a 90 integra using ?
