My mini tubbed coupe project
Awesome looking project!!
Any specs?
Any specs?
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Largo fl 33773
MV#72427
anytime . Its' not as hard as it looks. It's a whole lotta drilling and grinding, I had a bunch of more pics of it, somehow it got deleted off the camera. I've done a bunch of work to it, I've cut the old 8 point cage out. Put a 10 in . I've mini tubbed it, and had it all on the camera. Lost all the pics!
Thanks
It is an original 5.0 coupe. 3" cowl hood tubular qa1 k-member and control arms. upr coil over kit. upr caster camber plates.
Specs on the car
engine 393
forged chp crank
forged h beam rods
forged trick flow pistons
sfi balancer
the cam is a 621in. 627ex. comp cam
solid roller cam
trick flow heads that are ported and polished
set of 1.6 ford motor sports roller rockers
trick flow R intake
30 pound injectors
80mm pro m mass air meter
75 mm throttle body professional products
bbk long tube headers
X pipe
flowmasters
Transmission is tko 3550
aluminum drive shaft
upr adjustable upper Control arms
south side lowers Rear Control arms
ford motor sport 3.73
autometer pro-comp guages
tweecer rt programmer
msd 6al
zex nitrous kit
Specs on the car
engine 393
forged chp crank
forged h beam rods
sfi balancer
solid roller cam
trick flow R intake
30 pound injectors
X pipe
flowmasters
msd 6al
zex nitrous kit
