My 85 Coupe Project.....
Thanks guys,
Today I welded in the fuel filter mounting brackets, drilled and welded studs in the fuel cell mounting tabs..... Then I was able trim and weld in the last 2 pieces of the trunk floor..... I also made and welded in a filler panel where the gas tank filler neck goes through the trunk floor..... I primmed the entire trunk floor so it wouldn't surface rust while the car is getting the cage installed.....
The car is now ready to go to NBS for the cage install this week.....
In the mean while I will get the cover for the bottom of the fuel cell made, and I also need to make 2 small filler panels for infront off and behind the cell, these will be made of aluminum and pop-rivited in for possible access purposes later.....
I know how you feel,but you should sleep well if it's at NBS.
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
