My Little ITB Project
Old Dec 6, 2009 | 07:10 PM
  #41 (permalink)
MightyMaxGS-T's Avatar
lol who?
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Old Dec 6, 2009 | 08:51 PM
  #42 (permalink)
custom240sx's Avatar
DC Crew Member #1
Alpha...that comment was quite random
Mighty, who did your welding for the aluminum portion?
Old Dec 6, 2009 | 09:10 PM
  #43 (permalink)
thehondaconnection's Avatar
Originally Posted by MightyMaxGS-T
ok got you, my bad i just misunderstood you i guess. didn't mean to jump on you like that. pick my brain bro i don't mind, whatever questions you have i'll do my best to answer, we don't have to put it in a pm, i'm sure someone else may have the same questions. alpha said to put the 550s so i can run ethanol if i want to. i'm going to see if alpha will lemme use the moates 2 timer to have two different tunes on the flick of a switch.
That would be hot!One pump gas tune & another on e85.Or one on e85 & the other on spray!I see why you want such big injectors now with the ethanol.Doesn't Alpha recommend 750's though for e85?Are you planning on a wet or dry setup for your direct port?Did he quote you a price?
The Honda Connection
727-859-3216
Honda/Acura high performance&service
Swaps-turbo's-nitrous-custom superchargers-itb's-tuning-wire tucks-brake tucks-suspension
From your every day Honda to the all out racecar.$45@hour.PM,Text or Call for a quote
Old Dec 6, 2009 | 09:51 PM
  #44 (permalink)
He said all I need is 550s for the e85 if I remember correctly. I can up the fuel pressure if necessary to like 4 bar or so.
Old Dec 6, 2009 | 10:18 PM
  #45 (permalink)
What about the price & are you going to go wet or dry?
I found a site that has a selection of stacks for our applications.Pretty cool stuff,lmk if you want the link.
727-859-3216
Old Dec 7, 2009 | 05:17 AM
  #46 (permalink)
Alpha's Avatar
lol who?
You. I think you've been hanging out with Jose too much
It really isn't that random if you look at his coloration
I really recommend the Injector Dynamics injectors with E85. Especially for all motor applications as they handle higher fuel pressures better than any other injector I have used
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Dec 7, 2009 | 08:07 AM
  #47 (permalink)
lol why have i been hanging out with Jose too much??? lol what did i do that was like him??? sorry man my pockets ain't that deep for all motor injectors, i still have my truck to finish, i'm not buying shitty injectors i just dont have $500 to fork out for a set of injectors for my street car. lol no i'm not using dsm shit...
Old Dec 7, 2009 | 11:57 PM
  #48 (permalink)
price on what? i'm gonna go with a direct port wet shot. shared_pm me that link please.
Old Dec 8, 2009 | 10:57 AM
  #49 (permalink)
I was asking if Alpha had given you a price yet on your two map tune,Are you guy's going to tune the car alpha numeric style,or map & alpha-n together,did you guy's speak about that?
Maybe Alpha can chime in.
I am pm'ing you that link.lmk what you think & which ones fancy your liking for your Setup in the end.Their selection isn't Crazy huge but with some of the stacks they don't taper,some do.but even with the tapered + un-tapered ones you can cut them to desired length of course & with some of the tapered ones you could go with a smaller base to compensate for the length cut off so that your Base is still the same Dia. as your entry.So theres no lip to disturb airflow.
Btw,what is your build gonna consist of?Borexstroke,cams,comp.,Valve dia.etc
727-859-3216
