da turbo build
Old Oct 11, 2009 | 12:03 PM
sullivanracing06's Avatar
Default da turbo build
heres the history of this build so far,
bought a 90 da 2dr for 300, obd 0 s1 tranny and had a b18a with the number 3 rod sticking out of the front of the block.
b20b from a friend for 350.
greddy 18g turbo, cast manifold n outlet 125
random i/c and piping from my garage free
pr4 obd0 socketd ecu for 2.5 bar, 550s up to 21 psi
rc 550s
ive got a minty b18a that i pulled with 55436 miles, minty crank and sleeves, i bought a set of weiscos for 250 bnib, and eagle rods for 150, acl race bearing for 75 bnib, arp main, rods n heads. cometic h/g, and plan on using the factory b20 head w the ls cams for now.
id like to use the kms stage 2 valve train package, ne one use this package before? input on this set up?
blew the s1 and switched to a ys1 tranny w a obx lsd and act 6 puck with a7.5 lb flywheel
what do yall think of this set up?
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Old Oct 11, 2009 | 06:53 PM
FC_V8's Avatar
Nice setup btw. I used kms valve train on my d16z6 and i miss-shifted and went up to 9000rpm and it was still good. I never had an issue with them at all.
Old Oct 12, 2009 | 05:49 AM
another question, a freind of mine has the same spec tdo5-18g turbo on his subby and it seems to pull allot harder, im guessin its because of the cast greddy manifold and outlet elbow on the b series kit?
im loking at buying a 18g dsm divided outlet and fabbing that to work w my set up as well as a aftermarket b18 to dsm flanged tubular manifold.. this should allow for more top end correct??
Sullivan Racing LLC
352-665-2496-Tom
Old Oct 13, 2009 | 06:14 AM
cabron's Avatar
pic and bump
TR "eg" crew #37
Old Oct 13, 2009 | 06:17 AM
AllShowNoGo's Avatar
nice setup bro do a VTEC head that ls will SCREAM MAN best thing i ever did!
Old Oct 13, 2009 | 07:18 AM
rangcrx's Avatar
engine building &best
^im with him dont waste the money building up a Ls head..but the other stuff sounds good
i love AUTOZONE
Old Oct 13, 2009 | 07:35 AM
BoostedRacerDad's Avatar
Pops
+3 on Vtec head best money ever spent.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Oct 13, 2009 | 05:49 PM
im going for more or less tellin people ive got a factory ls bottom end
Sullivan Racing LLC
352-665-2496-Tom
Old Oct 14, 2009 | 12:06 AM
juiced2ndgenteg's Avatar
Don't waste your time/money on the LS head. Vtak all the way! Those greddy turbos are garbage IMO. Get a t3 manifold and a t3/t4 and be happy! Considering you have a pistons/rods Shortblock, a decent t3/t4 will make 375-400 on pump and be safe.
Old Oct 14, 2009 | 06:36 AM
lol who cares about tellin people is a stock ls block just say its a stock ls vtec !
