N/A Build B-seres pump gas
Old Oct 3, 2009 | 03:19 PM
tai mishuu911's Avatar
rut roh
in,
to see how well this does.
N/A GSR on its way.
StricKly MT 727-510-6301
WIREWORX 407 388-5809
Old Oct 19, 2009 | 01:26 PM
C Lo's Avatar
Originally Posted by mtber
Be careful with the pro3 cams.
Make sure you check & triple check your clearances p2v and v2v....
You will need to degree them in using a degree wheel fixture.
Personally I feel the pro3 cam maybe too large for your application.
I never had a problem with pro3 cams before. i used them on a build i had for my friend which was 14:1 c/r and had no issues
Old Oct 19, 2009 | 01:27 PM
C Lo's Avatar
Originally Posted by rangcrx
wow pro 3's.i just did a full blown N20 motor for osme with the pro2's and12:5ish i would not have went with the supertech springs i dont think they will take they lift from pro3s. but im with them make sure you clay that motor acouple times.. this is only going to be a track car im guessing right?
i never had a problem with supertech springs and pro3s before. this isnt the first motor i used this combination before. but thanks for the advice though.
this is going to be a daily car.
Old Oct 19, 2009 | 01:28 PM
C Lo's Avatar
Originally Posted by chi town brat
Moved to the Projects and Builds forum.
so you just did a polish or a port job as well?
chi town brat
S Mod
its only polished, and i am going to sharpen where the port splits to the valves
Old Oct 19, 2009 | 01:32 PM
C Lo's Avatar
here is a setup i did for my friend with pro3s and 11.5:1 c/r. it made 231hp and it idled at 1000rpms without shutting off, surging, fluctuating or anything.
a lot of people swear you need crazy compression to run these cams, but dont listen to anybody unless you try something out for yourself. the one thing my old teacher told me is to never listen to the people that says "they say" like "they say you shouldnt use that oil on this motor" or "they say you should have smaller slicks for that setup" and etc
C-Lo Tuning: B20vtec Dyno Graph - B20Vtec.Com...... B Series and Beyond
Old Oct 19, 2009 | 02:24 PM
rangcrx's Avatar
engine building &best
^so your telling me with a 13.2mm lift and a RACE only lube duration on thos cams you got it to idel at 1K im sorry i cant believe that...is that motor still running today if it was done 2years ago i would love to see it im sorry just cant believe it unless i see it
i love AUTOZONE
Old Oct 19, 2009 | 04:01 PM
  #17 (permalink)
C Lo's Avatar
of course its not together anymore lol. we get bored quick we up'd the compression to 12.5:1. im going to see if i can get in contact with him or anybody that i tuned with pro3s, so i can take a vid of the car idling.
for now this is the closest thing
YouTube - NY street race
if you go to the 2:15 mark you can kind of tell that the idle is low because in that vid the car is open header and its quiet. (dont listen to those kids in the end of the vid, idk who they are)
Old Oct 27, 2009 | 06:43 AM
  #18 (permalink)
C Lo's Avatar
UPDATE (10/27/09):
I got the valve from Erynn and installed it already so the head is good to go now.
The pistons just came in.
Still waiting for the rods to come in but anyways the next step is off to sleeve the block.
