Sponsored by: CARiD
Freaking boost spikes...
Old Jun 22, 2003 | 06:15 PM
Tony's Avatar
Senior Citizen
I noticed I got more consistent settings when I moved the pressure tap for the MBC to a different spot, although I cannot remember if I moved it from the compressor discharge or TO the compressor discharge, something about the intake manifold pressure (more accurate) as oposed to right at the compressor before the pressure drop of the intercooler, this might be a starting point for you, I know it plagued me with my DSM
10' 1198S
09' Ninja 500R
09' Stella
Old Jun 22, 2003 | 08:23 PM
Solar Specialist's Avatar
SOLAR-SPECIALIST.COM
Internal wastegate?
Old Jun 22, 2003 | 10:20 PM
orangespeed's Avatar
You should ask that little spanish kid with that orange mazdaspeed i heard he knows what hes doing...He solved his spiking and even beat a turbo civic running 7-9psi this weekend.
i'm only running 5psi...6 if its cold outside
Old Jun 23, 2003 | 07:38 AM
Levi's Avatar
sounds to me like stacking in the intake manifold..
custom parts is our perfection.
Old Jun 24, 2003 | 09:40 AM
MotorMatrix.com's Avatar
Boost creep with an internal gate is normal. there isnt a way to really elminate it. sometimes you can tightten down the actauator by a nut on the rod. it increases the boost but makes the actuator stiffer. not sure if it will work on your turbo though
Mike
MotorMatrix.com
R.A.W Racing
1.877.84.Motor
SFP.net
99' Civic Si NHRA Street Car 10.36@144mph 2850lbs w/ Driver
96' Civic NOPI Street Car now Sponsored by SFP. 2325 w/ Driver
