Turbo Position
Turbo Position
Ok on the mani that i am getting my turbo sits right in front so the oil feed and drain are sitting Horizontal. Now my question is which bolts do i loosen so i can turn it to make the feed and drain Vertical. I am guessing that its the bolts that are in the center of the turbo by the oil feed and drain. let me know thanks.
yah....just unclamp that belt looking deal, take apart the two housings...there should be a little metal dowel pin thing, take that out with a pari of pliers and then reattach the assembly.
Guest
Posts: n/a
ahh...all the one's i've worked with are from subarus...it has this belt that goes around it and clamps down, then you put a bolt through the clamp...hard to explain
Originally posted by Cronic
A belt??
Erm... do you mean the metal clamp? Or is this actually a rubber belt??
A belt??
Boost...it's a hell-of-a drug
