Ls motor
Ls motor
If I dont get my ls block sleeved, would it still be ok to go with endyn oversized 84mm 9.1cr pistons for boost. If so what kind of numbers can I look forword to with upgraded cams,rods,hondata,fuel pump,injectors t3/t4 turbo, tial bov, tial WG, Pwr IC. And where should I go to get the machine boring done.
thanks,
Joe
thanks,
Joe
if u dont sleeve the block 84mm out of normally 81mm ls block is not possible. u cannot bore a block that much and expect for the cylinder walls to hold. if u use normal 81mm pistons and get everything u said listed 280-300whp is something to look forward to on around 15psi
What if I go with 82mm pistons. My concern is that I JE pistons in this block before and I had to take them out because I was getting oil blow by, but I think it was because I had taken the block to Eisles and they honed it to max bore so I had to much clearence, any help or suggestions.
thanks,
joe
thanks,
joe
