help!
help!
I plan on running a custom turbo setup on my ls, with endyn/wiseco pistons, eagle h-beam rods. I need to know if I want to keep this car a daily driver what kind of boost numbers wood be good for this setup, and also what injector size should I be getting. Also should I get a bosch fuel pump. I already know I need a hondata. but what else should I be looking into getting for this to run right.
Thanks,
Joe
Thanks,
Joe
Guest
Posts: n/a
7h3 qu35710|\| 15 |\|07 h0\^/ much 1|\|j3c70|2 f0|2 h0\^/ much b0057, 0|2 \^/h47 fu3l pump.
7h3 f1|257 qu35710|\| y0u |\|33d 70 45k 15 317h3|2
4) h0\^/ much HP y0u 4|23 l00k1|\|g f0|2
B) \^/h47 MPH 1|\| 7h3 qu4|273|2
C) \^/h47 37 y0u 4|23 l00k1|\|g 70 4ch13v3.
1|\| 4ll h0|\|357y 7h0ugh, 4 537 0f 550cc 1|\|j3c70|25, 4 g00d |2u|\||\|1|\|g 570ck m070|2 (\^/17h h34d 57ud5), 4|\|d 4 p|20p3|2ly 51z3d 7u|2b0 4|\|d 5u|2|20u|\|d1|\|g k17, y0u c4|\| 3451ly 4ch13v3 260-280\^/hp 4|\|d d|21v3 17 3v3|2yd4y, \^/17h0u7 f34|2 0f l051|\|g 7h3 m070|2. 1'v3 d0|\|3 17 53v3|24l 71m35 f0|2 L5 0\^/|\|3|25.
P|20p3|2 pl4|\||\|1|\|g, 7h3 c0|2|23c7 p4|275, 4|\|d g|2347 7u|\|1|\|g (1|\| 7h47 0|2d3|2) 4|23 \^/h47 m4k35 0|2 b|234k5 4 537up. C0|\|74c7 m3 1f y0u |\|33d 4|\|y 4551574|\|c3 \^/17h 7h15
thanks John for the help. Im still new at this so all the help will be appreciated. this motor did have SRP 10.5.1 CR pistons in it with h-beam rods but ran into a lot of problems with those pistons so im thinking about changing to Endyn 82mm 9.3.1 cr pistons. I want to run around 12psi boost. So would 550cc injectors be good for this. And should I go T3 or T3/T4 for the street.
Thanks,
Joe
Thanks,
Joe
Guest
Posts: n/a
P3|250|\|4l ch01c3 \^/0uld b3 7h3 3|\|dy|\| p1570|\|5. F0|2 |20d5, 4ll y0u |\|33d |234lly 15 4 g00d 537 0f |20d b0l75 0|\| 7h3 570ck3|25 f0|2 7h47 4m0u|\|7 0f HP. Bu7 1f y0u'|23 0f 7h3 0p1|\|10|\| 7h47 "51|\|c3 y0u'|23 1|\| 7h3|23, m1gh7 45 \^/3ll", 7h|20\^/ 1|\| 4 g00d 537 0f |20d5. 34gl35 \^/0uld |\|07 b3 my f1|257 ch01c3. C|20\^/3|2, 0l1v3|2, P4u73|2 4ll m4k3 b3773|2 |20d5, 4lb317 f0|2 4 b17 m0|23 c45h. 550cc 1|\|j3c70|25 \^/1ll 5upp0|27 70 4|20u|\|d 400\^/hp \^/17h 4 \^/4lb|20/H0ll3y h1gh p|2355u|23 pump.
B0057 15 |\|07 4 g00d d3c1510|\| m4k3|2. 12p51 0|\| 4 5m4ll 73 \^/0uld y31ld 4 l07 l355 p0\^/3|2 7h4|\| 12p51 0|\| 4 73/04. 533m5 l1k3 y0u \^/4|\|7 qu1ck 5p00l, f0|2 7h47 1'd |23c0mm3|\|d 4 73/043 50 7|21m c0mp|23550|2, 574g3 3 3><h4u57 \^/17h 4 .48 h0u51|\|g. 7h47'd b3 4 f457 5p00l3|2 \^/17h pl3|\|7y 0f pull up 70p 45 \^/3ll.
4|\|y m0|23 qu35710|\|5? G1v3 m3 4 c4ll du|21|\|g bu51|\|355 h0u|25.
