nitrous
nitrous
question is when I hit the nitrous sometimes it seems to hesitate while its engaged ? is this air in the lines? I do not have a purge kit yet, should this solve my problem?
Guest
Posts: n/a
Usually its because of air in the lines. Try this. Arm the system, with the car in neutral, rev the motor to 3k rpms, and hit the button. The engine will rev pretty high. Do this 2 or 3 times and then spray it on the street. If it doesn't bog, you need a purge.
Just don't do it below 3K!!!!
Humanitarian, Philanthropist, Champion of the arts, supporter of single moms, and role model for misguided youths
