Boost gauge prob
Boost gauge prob
Well for the longest time, my boost gauge would go apeshit above about 17 psi , you could actually hear it, sounded like a bee in a folgers can. *shrugs*, turns out I needed a restrictor in the line to lessen the severity of the intake valves opening and shutting etc, nice boost guages have this built in, mine did not. It used to peak at about 22 psi, now it seemed to have averaged out and peaks at about 20 psi even give or take a pound or two on a cold or warm day
*edit*, before you ask why it peaks at all, my turbo has no wastegate, it makes whatever the engine can muster and sends it all to the intake.
10' 1198S
09' Ninja 500R
09' Stella
10' 1198S
09' Ninja 500R
09' Stella
I made a boost gauge out of a standard air gauge, and a wastegate is uneeded, the exhaust housing is sized fine, just makes for a little bit of lag, I don;t see 20 psi till about 2200 or so, which is 2/3rds of my rev range lmao, yellow line on tach starts at 3400.
10' 1198S
09' Ninja 500R
09' Stella
10' 1198S
09' Ninja 500R
09' Stella
Originally posted by Vapor
his truck is diesel, it came from the factory turbocharged and wastegate deprived. This is perfectly normal practice for turbo diesels.
10' 1198S
09' Ninja 500R
09' Stella
10' 1198S
09' Ninja 500R
09' Stella
Actually it is pretty redneck setup, ganked a PSI gauge from a hospital air pump I got at a flea market for ten bucks cause it had all the fittings I needed. , but it is a very clean setup, fabbed up a bracket and ran the line inside the a-pillar etc, looks pretty slick.
10' 1198S
09' Ninja 500R
09' Stella
10' 1198S
09' Ninja 500R
09' Stella
