Sponsored by: CARiD
lower boost + higher stat. comp vs higher boost + lower..
Old Jan 24, 2003 | 01:08 AM
Matt Vassallo's Avatar
lifelong learner
Default lower boost + higher stat. comp vs higher boost + lower..
all while on pump gas.
what are everyones views on this in the turbo honda world.
with the advent of hondata and other affordable engine management systems, the ability to tune either way is very easy. now, which way would you rather go, or which way do you think is better, and why.
please try to support all arguments with evidence of theory in the form of dyno charts, 1/4 et's, etc.
i dont want to hear everyones hypotheical crap, because all you idiots dont know what youre talking about half the time anywyas.
i'll post my ideas on this subject after a few replies. no i wont change mine.
rest in peace tim.
Old Jan 24, 2003 | 08:34 AM
lifelong learner
what's preventing a lower compressioned car to run 16-19 pounds on pump gas and putting out better numbers than the high cr car, and having a better power band due to a properly sized turbo?
rest in peace tim.
Old Jan 24, 2003 | 04:56 PM
0HP930's Avatar
Guest
Here is the bottom line though I know you already said you don't want to hear thermo theory about how engines work.
The two primary factors that control power output in a motor are actual compression ratio (boost+compression) and the mass/sec of fuel/air the engine can process.
Since the turbo is creating compression and increasing the mass/sec the engine can process by using energy that is normally lost in the exhaust gasses that is something you want to maximize through the highest possible boost.
Regular piston compression is stealing valuable crank power and limits the amount of boost you can run.
Before you go against this by thinking that you can run high compression and high boost by running pig rich, don't forget that you sacrafice the available power you can get from each gram of fuel/air the engine processes by doing so. The math could easily work out that whatever advantage you gain from increased boost is defeated by the power losses from a super rich mix.
For this reason the best combo for max power is low piston compression and high boost.
Intercooling, plumbing efficiency and good tuning is all about pushing the envelope of these basic principles.
The only downside of this combo is that your power output sucks until you hit boost, and this is the only reason for going against the low compression / high boost combo.
Its the only reason I want to bump the compression in my car from 7:1 up to about 7.5:1.
These are solid scientific facts that you can verify by looking at every high output turbo motor that is built to reliably to run on pump gas.
Reading a book on the subject of thermodynamics could also do wonders for you too.
Old Jan 26, 2003 | 10:30 AM
Slash's Avatar
THE HAMMER
well as far as i know.. the higher compression of a cylinder the less u can physically cram in there to explode right?
I dont feel like a sig today.
Old Jan 27, 2003 | 03:33 AM
Levi's Avatar
No, only if you don't compensate other factors to allow the higher PSI levels.
IE: Larger More efficent Intercooler, More fuel pressure, there really is no limit.
custom parts is our perfection.
Old Jan 27, 2003 | 04:45 AM
0HP930's Avatar
Guest
There is a limit before your mix spontaneously ignites which is known better as detonation. This is usually a very bad thing for motors with a lot of mix crammed into their cylinders.
How much you can cram in before this happens depends on a lot of factors which are controlled by things such as intercooling, tuning and plumbing efficiency.
This is where the fine art of knowing what you can get away with for a particular combo comes into play and I imagine is the kind of info Matt was really looking for in this post.
The scientist in me prefers to start with reasonable estimates of where things should be and let testing, tuning and other adjustments push things up from there.
Old Jan 27, 2003 | 06:48 AM
Levi's Avatar
MY Dodge GLH-S is 8.5 ratio, but your quote about 25 to 30 psi on TD street cars is almost correct.
I ran my GLH-S around on the street with 22 plus psi pushing 350 hp and 380 TQ....
