Sponsored by: CARiD
I want my 310's!!!
Old Nov 21, 2002 | 11:30 PM
StreetDriven's Avatar
I <3 your mom
Originally posted by "CronicBurn"
OBD2 + Hondata + tuning + injectors + resistor pack = $1000.00
= a car that will run great
Old Nov 25, 2002 | 12:03 PM
2qk4u's Avatar
when i put prelude injectors on my ls/vtec my shit would not idle at all, it just shut off.
all i did was adjust the screw on the throttle body till the car idled good.
Old Nov 27, 2002 | 01:44 AM
Durdan's Avatar
No Ants Drift Member
first off, check the resistance across the terminals on the injectors. if they are around 12 ohms, there should be no reason why it wouldnt work. if they are around 2-3ohms, they are low impedence and need a resistor box to step down the voltage to the ECU which could cause your problem. that and your fuel pressure may be off or you didnt reset the ECU
RIP Tim. i miss you, buddy
