*jucein alot*
i have a semi,fully built LS and im praying 175 shot and yes it takes it .....what im on here about is that i ran this type-R and i won so they kept on re-running me over and over in till i broke....... im wondering why bearing #3 main had some discoloring ? (lack of oil)OR(just the amount of cylender presseur exzerded on the crank ,,, .. my crank is fine for a littile dis color and a scrach on #3
main its going to be (microed) but i dont know if it was the thosand run or oil pump faiure god this is confuzing and what type of bearings should i use
next time Q*(i rev 89K) any suj
mabe a gurdel
or new pump
mabe a gurdel
or new pump
well something legible would be nice to help you out with...
scorched bearings could be caused due to lack of oiling...best guess without seeing it would be that your clearances were too tight for high rpm
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
maybe reving to 89,000 rpm has something to do with it?
if you want advice on TR, all you'll get is assholes flaming you for stupid shit instead of helping a fellow street racer........
get a better tourque wrench then that harbor freight shit then check your tourque specs again !?!?!?!! you know its not lack of oil cause your oil pres is always around 80 last time a saw it!
AP1 S2K
MEGANSTOPTECHMISHIMOTO
AP1 S2K
tourqenstine? hmm seems about right when u drive a acura
loads of torque therejfwy
