N2O on a silverado
Im running a wet kit on a 2000 chevy silverado, i have it set for 100 shot, do you think this is to much or can i go bigger i dont have anything upgraded (injectors and fuel pump) I just got my transmision rebuild after installing N2O but the fact that it had 200,000 miles on it didn't help eather. its rebuilt with better heaver grade stuff its almost bullet proof. so I shouldent have a problem with that, the engine has about 40,000 miles on it.
trying to remember if its the LQ4 or LQ9..
anywho...ive seen people run up to 250 shot (staged) on a stock bottom end...just have to make sure your fuel and timing are spot on...cause 1 hiccup can cause alot of headache....if your looking for a little more 1/4 performance from it...possibly consider getting a larger converter.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
