Sponsored by: CARiD
TurboXS RFL Q
Old Jul 22, 2005 | 01:10 PM
Sneakin Deacon's Avatar
PSSHHH x2
Default TurboXS RFL Q
alrighty, i wasnt sure where to put this, but since its part of a power adder setup, why the hell not in here right.
anyways...i cant hear mine. at all. its blowing off and all, but i cant hear it...what could be wrong? is my car too loud?
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Jul 22, 2005 | 07:49 PM
GsEclipse02's Avatar
it should be Really Fucking Loud from what i here.... try tradeing it with some 1 else who has an rfl
Old Jul 23, 2005 | 09:17 AM
PSSHHH x2
yea, thats what ive been doing...but it isnt loud and ricey and stuff....which is what i wanted....oh well, i needed to replace the pos bosch plastic thing anyways.
and simple is giving it way too much credit...its a damn spring, that puts load on an opening..similar to a valve in our heads, just this is providing downward force.
i just figured the small t25 people running around with em can make the noise at like 15psi...i would be able to manage it with a blower that flows much more air at 5psi.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Jul 29, 2005 | 06:12 PM
57trim's Avatar
It is dirty Kenny, the same thing happened to me, but it is cool cause it doesn't bleed off the boost and when you shift you just rocket right out, but it messes up you Turbo or blower that way.
Anyways open the top where the spring is and clean off any debris that is inside I bet you that will help cause when I had 5 psi it was still loud as hell.
DEATH MACHINE 2.0v. K-powered
Old Jul 31, 2005 | 06:15 PM
Solar Specialist's Avatar
SOLAR-SPECIALIST.COM
I dunno, mine is pretty damn loud at 7psi on my setup. And I can get it to go off easily in neutral.
