Sponsored by: CARiD
Turbo Questions: Plumbing
Old May 19, 2005 | 08:45 AM
Cecil's Avatar
gone fishin
Default Turbo Questions: Plumbing
What if any losses would result in utilizing a rubber hose for such a large section of the up-pipe versus standard aluminum plumbing?
What if any flow losses would be realized with the number turns and bends in the charge tube?
Below is a pic of my current configuration.
I just got the kit back from the fabricator and was surprised to see that big ole Blue Rubber Tube
Old May 19, 2005 | 09:08 AM
TNathe's Avatar
the only downside to using rubber (that I know of) for pipe is under high boost pressures it may swell and over a long period of time with extreme heat then cooling then heating it may deteriorate like coolant hoses do. That is an odd tube, it appears to transitions from one size to another, it reminds me of a two stroke expansion chamber how it is skinny then get fat, then skinny again. I say hmmmmm.
Old May 20, 2005 | 07:17 AM
DriftingDJ's Avatar
240LSX
should be alright I have a big elbow coupler like that coming off my turbo and it holds up I think for your setup should be alright just keep checking it cause it does swell enormously so you dont want to be swelling and rubbing anything cause they wear holes quick.
Old Jun 15, 2005 | 09:12 AM
CostaSpeed's Avatar
If anything the expansion may cause more lag than if it where all solid. But it looks like you can afford it,and with no intercooler your not going to feel it. That bike is sick. SICK, SICK, SICK!
Old Jun 29, 2005 | 04:52 AM
turbo-max's Avatar
The G-14 Classified
just dial in a few more pounds of boost...everything will be alright
Boost...it's a hell-of-a drug
