oil line for turbo
I was wondering if instead of putting a t fitting off the stock oil pressure sensor if I could just tap off the oil filter adapter that I am using for the aftermarket oil temp and pressure? I'm thinking it's the same but want to make sure.
It's a autotecnic oil filter adapter that has four 1/8 npt threaded holes. 2 holes have the sensors for the above mentioned gauges and 2 have threaded plugs. instead of having a male/male npt to go from the block to t fitting, then t fitting, then male to male npt/an adapter to hook the oil line to. I figured less places to leak if I can just thread the male/male npt to an adapter straight into the oil filter adapter. thanks for the confirmation.
