Sponsored by: CARiD
street tuning vs. dyno
Old Aug 1, 2004 | 06:12 PM
kender's Avatar
gadget man
Default street tuning vs. dyno
I have a a b16 crx that will soon be turbo'd and converted to obd1 and will be running hondata. I am on a budget so what I want to know is would I be ok street tuning the entire spectrum, what i mean is instead of street tuning to 70% throttle and dyno tuning 71% and up, could I street tune all of it? this is my daily driver and will only see the track for 1 day after the turbo goes on and then again after I sleeve the block and have a built motor.
basically I want to save the money on the dyno time to be able to spend it on parts for my car.
what would be the pros and cons of doing this?
thanks
U.S.S.A Crew Member #001
Old Aug 1, 2004 | 06:22 PM
0HP930's Avatar
Guest
The only con to street tuning is getting a ticket while doing so.
Save the dyno for a confirmation of what you are putting out at the wheels.
Old Aug 1, 2004 | 07:59 PM
kender's Avatar
gadget man
if that's the case then does anyone know where to street tune without running the risk of getting a ticket??
Old Aug 1, 2004 | 08:21 PM
99B16Si's Avatar
street tuning if u have a good wideband can actually be more accurate because its actaully puting the extra load on the motor from the weight of the car.
things such as igntion timing and cam timing can be optimized on the dyno tho because the power gains off the two are usually not enough to notice with the ass dyno
Old Aug 1, 2004 | 08:32 PM
1slowaguila's Avatar
El Grouch Racing
Go to the middle of nowhere and do it.Pm me if you need some ideas and i can give you some roads.Damn havent heard of a turbo crx on this board since i had one.Power to weight ratios in your favor rocks.
Oscar
90 Tsi=FOR SALE $1500 O.BO
93 Eg Hb=b20vtec wit nawz
Rotary Farm Vato Locos crew member #0 biatch
Old Aug 1, 2004 | 08:46 PM
kender's Avatar
gadget man
i plan on using the aem uego wideband gauge style unit, and when I get ready to get rine tuned for optimum hp then I'll hit the dyno, but for now I want to get on the road and let the ass dyno feel the difference from the stock 160hp to the 10psi turbo hp.
Old Aug 2, 2004 | 08:21 AM
NChatch's Avatar
i stepped on my weiner!
well actually hondata tells you that you MUST do some kind of "street tuning" for a lower end map, and then like you said a high throttle map, this is why hondata tuning is supposed to take so long.
i have already had my car tuned for WOT @ coastal and am very happy with it, me and sam did a nice job. but i forgot to do any kind of partial throttle tuning, so for 3 days i have been driving around with the wideband and logging, and seeing the different loads and throttle points to adjust at, after 3 days i have a good OFF WOT tune and still remained the same for WOT.
if you wanna save some money go get uberdata and scrap the hondata and save yourslef a shitload of money, i did and am happy as hell with it
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
