Sponsored by: CARiD
nitrous
Old Jul 6, 2004 | 05:21 PM
evo.end3R's Avatar
HATORADE
Default nitrous
im thinking about running a small wet shot, like around 50-60 in my car, its got a 5.6Lv8. i am looking for peoples suggestions as to if i should replace anything so i dont blow the engine, thanks.
Old Jul 8, 2004 | 04:26 PM
Krautburner's Avatar
Scissor me timbers!
No, don't do it. You will tear into your teflon coated walls.
Old Jul 9, 2004 | 07:15 AM
DeadSexY's Avatar
diballacully slow
just drill a hole into the air intake,hook it up and spray way!
j/k dont doit
Old Aug 1, 2004 | 04:23 AM
terry.ho's Avatar
I love to choke people.
If this is an older vehicle replace the fuel pump. Other than that starting hitting the happy juice.
Originally Posted by fresh&clean
This is the worst place to get any advice at all.
http://www.myspace.com/terry_ho
Old Aug 3, 2004 | 10:27 PM
95Ride's Avatar
Gangsta What
if its new you should be ok but i wouldnt go any higher than a 50 on stock parts....invest $ in getting the right internals then spra or boost...make it more efficient and dont listen for a bearring to spin and rod to snap or your wall to crack every time you get red button happy
Old Aug 4, 2004 | 04:26 AM
BigBadBuick's Avatar
Livin' Large
I thought we did this in GCC a while back? As long as you have enough fuel and your timing is right, you should be safe with a V-8 up to the 100-125 range. Honestly, a 50 shot on your heavy car is going to feel about the same as driving on a cold morning. You'll know you're making a little more power, but it won't be enough to get excited Weren't you having tranny problems? If so, forget about nitrous, the tranny's the first to go.
