Sponsored by: CARiD
fuel filter
Old Apr 30, 2004 | 06:27 PM
kender's Avatar
gadget man
Default fuel filter
I am thinking of replacing the stock fuel filter with an aftermarket one and want some input on what would be best for a turbo setup? the current filter is not giving me problems yet but i figured while I was replacing injectors and fuel pump why not?
I think the filter that is in there last saw daylight at the honda plant back in 88 ( ok 87 when it was actually made ).
U.S.S.A Crew Member #001
Old May 1, 2004 | 02:36 PM
kender's Avatar
gadget man
what fittings would I go with AN or NPT??? never had to deal with fittings till I started the turbo stuff. is there somewhere around here that stocks that stuff?
Old May 1, 2004 | 03:05 PM
kender's Avatar
gadget man
does anyone know what size the stock banjo fittings are?
what is a good aftermarket filter setup? I am thinking aem but its $$$ would a cheaper filter do the same since aem says the filter is replaceable with the stock honda filter, wouldn't any aftermarket do the same as long as it is for my car?
what AN size would the stock fuel lines use, -6 or -8, so that I can remove the banjos
