Sponsored by: CARiD
which wastegate??
Old Apr 25, 2004 | 01:34 PM
luderacer's Avatar
Dain Bramage
Default which wastegate??
what is a good waste gate. i am planning on running between 9-12 lbs on my honda prelude. i have a t3/t4 turbo but not installed. and what size spring should it have? thanks
-joe
im like a sore dick, ya just cant beat me!!
Old Apr 25, 2004 | 03:25 PM
luderacer's Avatar
Dain Bramage
anyone ?
Old Apr 29, 2004 | 03:15 PM
kender's Avatar
gadget man
I have heard tial is one of the best. I have a tial ( not yet installed) but I got opinions for about a month before I got it.
as for the spring it really depends on if you are running a boost controller or not. If you plan on running 9lbs at the lowest then I would get a 7lbs spring and run an electronic boost controller such as the blitz sbc id. If you don't plan on a boost controller then you want to get the spring for what ever boost level you want to run all the time.
I say go with a boost controller.
U.S.S.A Crew Member #001
Old Apr 29, 2004 | 07:15 PM
99B16Si's Avatar
go with a tial 38mm for 40mm depending on the flange u use
Old Apr 30, 2004 | 06:33 AM
luderacer's Avatar
Dain Bramage
actually the mani i bought came with a 35mm tial with a 12lb spring. where would i buy a smaller spring like 8-9 lbs.?
-joe
