Sponsored by: CARiD
which precision turbo???
Old Mar 13, 2004 | 06:10 AM
NChatch's Avatar
i stepped on my weiner!
i know you did!
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Mar 13, 2004 | 10:32 AM
qitstrn's Avatar
Can you spot me 20 cars?
Default Re: which precision turbo???
Originally posted by NChatch
hey guys, i should be upgrading my bottom end on my civic in a few weeks. it will be a 2.0 from a 1.8,B18. fully sleeved, 9:1 comp ratio, Je piston, crower rods.
now i want to upgrade my turbo to something a little more efficient, i see a lot of people using precision turbos, but i dont know which one would be the best for my application, right now i have just a normal T3/T4, and i am using RC440s, i would like to make as close to 400hp as possible, also my turbo manifold is for a T3.
so which ones could i use, i will not be revving over 8200.
I could only make 300whp safely on 440's. I made 325whp but the injector duty cycle was at 94%. That too high for me. Like john said an SC50 would be the turbo i would run. They are good up to 470hp. good luck with your project.
Old Mar 13, 2004 | 11:06 AM
NChatch's Avatar
oh im sorry i did forget to mention, that i would be upgrading injectors, i am slightly retarded sometimes. thanks though
owner/operator
Old Mar 13, 2004 | 11:20 AM
Alpha's Avatar
Like john said some bigger injectors. I would recommend 880cc injectors. As for the turbocharger I would recommend either an SC50 with an E compressor housing, .63 A/R turbine housing and a 76 trim turbine wheel or the same specs but an SC34.
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Mar 13, 2004 | 07:38 PM
NChatch's Avatar
you guys know too much, but im glad
owner/operator
Old Mar 13, 2004 | 07:42 PM
quickcivic's Avatar
addicted to boost
I upgraded to a SC61 and am loving it ever since.
Old Apr 26, 2004 | 05:23 AM
  #17 (permalink)
rj2173's Avatar
TR's cuban!!
the precision SC61 is the one that im going to use for my turbo kit, along with a tial wastedgate, SFP exh mani!
Old Apr 26, 2004 | 04:35 PM
  #18 (permalink)
PoppaSmurf's Avatar
Chowdah-head
grave digga!!
Poppa J. Smurf
